I am trying to design a simple loop of communication system between pc and FPGA virtex 5, for this purpose I interfaced a BRAM with uart module, I am using VHDL as the hardware description language, the memory used is a 16 byte simple dual port BRAM ram with a width of 8-bits; is supposed to read 16 bytes of data from a terminal software and then sending them back to it, the problem is that I cannot write the first address(addra = 0) and the writing starts from the second address thus I can write only 15 bytes in one pass, here is the code of the fsm used to implement the system
proc_next_state: process(clk, reset, state)
begin
if reset = '1' then
state <= idle;
elsif (rising_edge(clk)) then
case state is
when idle =>
wea(0) <= rx_dv ;
dina <= rx_byte; -- input of BRAM's port A.
ENB <= '0'; -- Enable signal for port B
tx_DV <= '0'; -- data valid signal for uart transmitting interface.
tx_byte <=(others => '0'); -- byte to be loaded to uart transmitting interface
if rx_dv = '1' then -- data valid signal for uart receiving interface
state <= writing; -- if rx_dv is asserted move to the writing state
else
state <= idle; -- keep idle
end if;
when writing =>
if addra = "1111" then -- if the whole block is written move to the reading state
state <= reading;
else
state<= idle;
end if;
wea <= (others => '1');
dina <= rx_byte;
ENB <= '0';
tx_DV <= '0';
addra <= addra + 1;
tx_byte <= (others => '0');
when reading =>
wea <= (others => '0');
dina <= (others => '0');
ENB <= '1';
tx_DV <= '1';
tx_byte <= doutb;
if addrb = "1111" then -- if the 16 bytes data are fully read move to state done
state <= done;
else
state <= waiting;
end if;
addrb <= addrb + 1;
when waiting =>
ENB <= '0';
tx_DV <= '0';
if tx_done = '1' then
state <= reading; -- read a new byte when tx_done is asserted high
else
state <= waiting; -- keep waiting
end if;
when others => -- remain in this state for one clock period then move to idle
wea(0) <= '0';
ENB <= '0';
tx_DV <= '0';
addra <= "0000";
addrb <= "0000";
state <= idle;
end case;
end if;
end process;
This portion of code is for the signals that I used for simulation purpose
Din <= dina;
Wra <= wea(0);
Rdb <= enb;
i_rx_DV <= rx_DV;
o_tx_done <= tx_done ;
dout <= doutb;
o_rx_byte <= rx_byte;
w_SM_Main <= "000" when state = Idle else
"001" when state = writing else
"010" when state = reading else
"011" when state = waiting else
"100" when state = done else
"101"; -- you should not reach this value
The following picture shows the simulation results of writing dina to addra = 0
And this picture shows the simulation results of reading doutb from addrb = 0
Can u please tell me why am I reading value 0 on addressb = 0 even though the first value received is different from 0 ?
