14
On circuit diagrams, C stands for Capacitor, R for Resistor, L for inductor (for Lenz) as explained here, but why is U used for ICs on circuit diagrams?
Russell Gallop
  • 243
    This question is *not* answered by the question that it is marked as a duplicate of. That asks *what* symbols means, this is one particular *why* question. I hope I've now made this clear by editing the question. – Russell Gallop Jan 20 '17 at 18:18
  • [ANSI/IEEE Std 315](http://standards.ieee.org/findstds/standard/315-1975.html) (1975) has that information – Brian Carlton Jan 25 '12 at 17:19
U was originally the designator for "unspecified". I suppose that made sense when integrated circuits were new. There was no existing category for them, so they went into the none-of-the-above category. I use "IC" as a designator for ICs because I think it makes more sense, especially nowadays when ICs are common.
ctype.h
  • 215
Olin Lathrop
  • 310,974
  • 428
  • 915
    Whoever downvoted this, it would be useful to know what you disagree with. – Olin Lathrop Jan 22 '17 at 12:56
  • I downvoted because [this Altium article](https://resources.altium.com/pcb-design-blog/getting-started-in-altium-designer-the-schematic) states 'For trivia fans, the origin of the reference designator "U" meant "Unrepairable"', *not* "unspecified". Is there a source you can provide that contradicts that? – Charles Clayton Jan 21 '20 at 22:09
13
Good question - "U" stands for:
inseparable assembly
integrated-circuit package
microcircuit
micromodule
photon-coupled isolator
I think the U was picked because these are all classed as "Unrepairable", since they are all in sealed packages.
FWIW, the designator for separable assemblies is "A"
Note that it was actually "IC" (and other things - for instance I've seen Z used) before it changed to U. If you look at schematics from pre ~1980 you will see a lot of different (to todays standard) designators used, e.g. CR or V for diode, G or X for crystal, etc
Oli Glaser
  • 54,990
  • 76
  • 147
  • Not debating you or anything, but even back before integrated circuits existed there were other components that were sealed and pretty much unrepairable: Transistors, vacuum tubes, electrolytic capacitors, carbon resistors, diodes, ... I haven't heard of anybody trying to repair any of those things either. – Solomon Slow Jan 29 '19 at 22:07
  • I believe this is the correct answer. This [Altium article](https://resources.altium.com/pcb-design-blog/getting-started-in-altium-designer-the-schematic) states 'For trivia fans, the origin of the reference designator "U" meant "Unrepairable"'. – Charles Clayton Dec 10 '19 at 20:12
