I have AC signal that varies from 50mV (pk-pk) to 420mV (pk-pk). I am trying to use a PGA (programmable gain amplifier) to amplifiy the signal so that it can be sent to the ADC in an ATmega328P. The signal sent to the ADC needs to be within 0-3.3V. I can't add a DC shift centred around 1.65V before passing it through the PGA, as this will also amplify the DC shift, which puts the signal outside the ADC range. How can I go about shifting the signal and amplifiying it using a PGA which is supplied from a single supply?
Asked
Active
Viewed 209 times
2I guess that your PGA didn't come with a datasheet or model number, otherwise you would surely have mentioned such an important detail. – pipe Sep 07 '16 at 05:13
I didn't include the PGA model number as the model I will use has not been decided yet. I was considering the MCP6S91. – tamilnewzealand Sep 07 '16 at 07:50
Yes you can, and you have to. The PGA you want to use, MCP6S91, can only operate on positive signals, centered around a positive DC reference voltage. It has a dedicated VREF pin for this exact purpose.
There is even an example in the datasheet for a 2.5 volt DC bias:
pipe
- 13,748
- 5
- 42
- 72
