I am extremely new to circuits and using transistors, but after reading many other posts and articles I am still confused about terms and not sure if I am understanding this correctly.
I have been trying to use raspberry pi to use as a switch to turn on a motor. However I realized that I could not use PN2222 as the current limitation IIUC is less than a few hundred mA, much less than 1.5A. So I have been trying to get a new transistor but have been very lost on reading the datasheet. After much research, I think I have the basics, but wanted to double check from the experts here whether what I am doing is not going to blow anything up.
My main guide has been this post: Need help calculating resistance for transistor base
(Tried to simulate this but I don't seem to be getting any useful data - getting 0 V everywhere or N/A)
Datasheet: sheet
Questions
- So the motor I have is 12V which takes in minimum 1.5A. Using I=VR, does this mean that the resistance is 8Ohm and so I should use 8 Ohm in my calculation?
- If I understand correctly, to calculate how much current is required from base, I need to use \$h_{FE}\$. At 1.5A collector current, gain is approximately 30 (from the graph, although I am not sure how that \$V_{CE}=4V\$ actually affects anything). So to support 1.5A, does that mean \$I_b\$ needs to be \$\frac{1.5A}{30}=50mA\$? If the max the source can output is 16mA, is the max current going through collector->emitter \$16mA * 30 = 480mA\$?
- So the base resistor required would be \$R=\frac{V_{BaseResistor}}{I_B}=\frac{3.3V - V_{BE}}{50mA} = \frac{3.3V - 1V}{50mA} = 44Ohm\$ But since I can't do 50mA, do I just calculate this for 16mA?
- From the calculation above, it seems like I can't actually use my current setup to enable the motor properly. Is this correct? In this case, is it better to get a new transistor (is there a way to find correct transistor more easily?) or is it possible to provide external power to increase amperage provided to transistor?
Sorry if my questions seem all over the place I'm still very confused whether whatever I am doing is correct.
