I've been reading up on NOR and NAND memories in search of an answer as to why exactly is NOR a XIP (eXecute In Place), and NAND is not. While both of the links were extremely informative and well-written, neither explicitly satisfied my curiosity.
I think I understand the basic pros and cons of both kinds. The way I see it, NOR memory is suitable for program storage, instead of data storage, because it has fast read times, and horrendously slow write/erase times. Clear so far. Also, NOR offers true random access (due to the NOR gates, which are essentially parallel and not serial, if I understood it correctly), as opposed to NAND, which typically works on the level of words, serially, not individual bits.
This made me think that the XIP part is somehow due to the ability to access every individual bit, NOR being random. I am, however, not fully convinced this is so. Is that right, or am I spouting nonsense?
A followup if it indeed is so - I've gotten the impression that NAND actually can be implemented in a way that achieves random access (although there is no real reason to do this, AFAIK). Could XIP theoretically then also be achieved with such NAND memory?
ReoTheYokel
  • 73
XIP requires random access -- the CPU needs to read the instruction stream as it executes it. If there is a loop, it needs to re-read the same instructions again (unless they are cached). If there is a branch, it needs to follow it without a delay.
NAND flash interfaces are usually designed to allow blockwise access only. If you want to execute code from that memory, you'd either read the entire block and discard everything but the instruction you are interested in (which would be horribly slow), or you add a caching mechanism.
There are implementations that implement XIP in NAND by catching a page fault, reading a block into cache and then pinning the cache to the virtual address space. With programs optimized for it (there are compilers that understand paged architectures and know to align code so functions calling each other end up on the same page) you don't lose much performance.
Note that for anything but large production runs, all these considerations are pretty much obsolete. RAM is cheap enough that for a few thousand units the difference in hardware cost is still smaller than the difference in engineering effort.
Simon Richter
  • 12,031
  • 49
  • Ah, I see. And the blocks in NAND are, what, in the kilobyte range? Also, a follow-up question to the "obsolete" part - I was reading up on it because it came up whilst learning about the iPhone 1 architecture. Is it obsolete in laptop/desktop discussions (if it ever actually was applicable), or is it obsolete in embedded systems as well? Thanks for a concise answer! – ReoTheYokel Aug 28 '16 at 16:39
    Usually 512 bytes to a few kilobytes. Anything with enough memory would usually use XIP to bootstrap the RAM, then copy the code over because the RAM is still faster (for PCs, that was called "BIOS shadowing"). For embedded, it's mostly obsolete as well, as modern MCUs have boot logic that can read a NAND block to cache memory and execute it. – Simon Richter Aug 28 '16 at 21:14
  • So could the NAND block size be reduced to a single byte and the flash would become XIP-compatible then? – Melab Dec 19 '22 at 18:16
  • @Melab, yes, but then the density would decrease below that of NOR flash. The point of NAND flash is that it's cheaper and more dense. – Simon Richter Dec 19 '22 at 18:22
  • So what makes byte-addressable NOR flash denser than byte-addressable NAND flash? Is there any rewritable, XIP-compatible non-volatile storage technology that can achieve greater densities than NOR flash? – Melab Dec 31 '22 at 13:42
  • @Melab, the increased density is achieved by connecting multiple cells in a chain, which reduces the number of interconnects, but also means all the signal paths are longer, decreasing speeds below what is useful for XIP. NAND flash can still individually address bits, just not as efficiently, and XIP mostly depends on latency, not throughput. XIP is mostly irrelevant today, so no one is building larger XIP capable memory. – Simon Richter Dec 31 '22 at 14:48
