Yesterday I tried to solve a question in a second order circuit , but I couldn't ! because I have problem understanding the concept of 0+ , 0- ! So let me try it in a first order circuit , it supposed to be much easier :
Is there any thing wrong !?
Understand the behavior of Capacitor. see this
Not sure about remaining questions but Generally you have to find the Time constant(RC) to find the voltage across the capacitor and substitute in this formula,
\$V(t)=V(1-e^{(-t/RC)})\$
Change the values of 't' according to your requirement.
The usual use is that \$ t=0^- \$ represents the instant before the event. In this case the switch is closed and has been for some considerable time while \$t=0^+ \$ is the instant after the event i.e the switch has just opened.
if we consider \$ t=0^-\$ then we can ignore the capacitor as it is charged to some voltage and therefore has zero current flowing through it.
We therefore have 2A flowing into 10R is parallel with 15R which is 6R so we have 12V across the current source. Now considering \$R_1\$ and \$R_2\$ as a potential divider this gives us 8V across \$R_1 \$ and hence \$C_1\$.
Now you can't change the voltage across a capacitor in zero time so
\$V_c = 8\text{V}\$ when \$t=0^-\$ and \$t=0^+\$
Once the switch is open the capacitor starts to discharge via \$R_1\$ giving
\$V_c = 8 \cdot e^{-\frac{t}{C_1 \cdot R_1}}\text{V}\$ for \$ t \ge 0.\$
