12
I'm currently designing a board that is attaching a 12bit ADC (MCP3208) to a Raspberry Pi (besides a few other low speed I/O related stuff). It will mostly be attached to analog sensors (temp sensors, IR distance sensors and similar things, while not always needing 12bit resolution, there are cases where it would really be nice to have that extra chunk of information).
I don't have much experience with analog circuitry and don't have a good understanding of the underlying math and physics involved.
I'm reading into several design guides regarding ADCs and often read about things like anti aliasing filters, ADC drivers for high impedance signals, analog ground planes, laying out traces in certain patterns to reduce noise, keeping high speed digital electronics separated as much as possible from the ADC to reduce switching noise, precision voltage references and much more stuff that I don't fully understand yet.
So what I started wondering was if it even makes any sense for me to use a 12bit ADC, if I don't have the expertise to implement it correctly because I may loose 2 LSBs anyways because of sub-optimal circuit design and should rather just go with a 10bit ADC. Or is optimal circuit design not as crucial in the 12 bit realm as I come to believe it is.
What are things that should always be implemented to reduce noise (f.e. the obvious bypass cap)? What are the biggest causes of noise in an mixed signal application like mine (having a GHz processor talking to the ADC)? What are the things that are actually only needed in higher accuracy applications (14-16bit+)?
I would really like to know what are sensible and essential things that I should look out for.
timonsku
  • 1,368
  • 30
    Start with what you're trying to measure, and what sort of resolution you need, and then decide what sort of ADC and analog processing you need. As an aside, read your ADC datasheet. You lose bits even if you use it perfectly. Search for "ENOB" – Scott Seidman Aug 19 '16 at 00:12
  • The problem is that the things that I will need to measure will constantly change. Sometimes I need to see every voltage blip possible, sometimes even 8 bits would be enough. I would like to have a solution that can cater to as many applications as possible. – timonsku Aug 19 '16 at 00:29
  • How fast do you need to be able to see changes? (i.e. what sampling rate are you after?) – ThreePhaseEel Aug 19 '16 at 00:40
    "Sometimes I need to see every voltage blip possible, sometimes even 8 bits would be enough." Then your requirements are to be able to "see every voltage blip possible". If you need 12 bit resolution even only occasionally, you need to design with 12 bits. If you go to 10 bits, you'll not have 12 when you need them. – WhatRoughBeast Aug 19 '16 at 01:43
  • A sampling rate of 1Khz+ would be preferable. Though I think in most applications 120hz would be good enough. Though that sampling rate would be need to be possible for 8 channels at a time (not at the same clock but they all need to be sampled consecutively). @WhatRoughBeast Yes thats what was my reason to decide to go with 12bits. Though I need advice with implementation here. – timonsku Aug 19 '16 at 11:03
  • The datasheet of the device you are looking at states (section 6.2) you need a minimum clock rate of 10kHz to maintain linearity due to self-discharge of the internal sampling capacitor. This does not affect the overall sample rate. – Peter Smith Aug 19 '16 at 11:56
  • Sure but I don't see how this is relevant to the question? – timonsku Aug 19 '16 at 12:26
For a medium-precision, low-sample-rate mixed-signal application such as yours, the main problems you face are having an accurate enough reference and keeping digital switching noise out of your ADC. There are several steps to this, starting at the design phase and continuing through board layout.
During circuit design
First, at the design phase, a proper reference, correct decoupling, and a low-impedance signal drive must be supplied to the ADC in order for correct conversions to occur. Also, the signal must be filtered (low-pass filtered in an instrumentation app like yours) to prevent the ADC from effectively downconverting higher frequencies to baseband (RF apps can use a slow ADC + bandpass frontend filter to Nyquist-downconvert a signal, saving on a dedicated mixer and LO).
Stabilizing your reference
References range from the trivial and pathetic (a jellybean discrete Zener, good to oh, 4 bits) to the insane (ovenized IC buried Zeners, used in high-performance instrumentation applications) -- and the specifications are often not clear, mixing units in ways that confound novices. The chart in LTC AN82 is a useful antidote for this -- given your application, where your ADC is a 12bit unit capable of 11+ ENOB given a stable reference and a 5V supply, I would specify the reference to be accurate to 0.02% or better across the temperature range of interest, and RMS noise is not a concern as it's about an order of magnitude less than your accuracy specification.
Unfortunately, 0.02% initial accuracy without a trim is about where things start getting rather...hard. Using a 4.096V reference given that the ENOB performance desired means that I want to run the ADC on a quiet 5V supply with a logic-level translator to the 3.3V I/O of the Pi, and that 4.096V gives you a nice, handy 1mV/count relationship, we're limited to the ADR4540, the X60003, the MAX6126AASA, or perhaps the LTC6655B although the last part cuts it close as it has a 0.025% initial accuracy. While tempco and hysteresis are not concerns as this is a bench application I presume, and line and load regulation are not major problems as this is powered from the same regulated 5V supply as the ADC and only driving the ADC's Vref pin, long-term drift is also a concern here due to the lack of a trim -- for this, the ADR4540 and MAX6126AASA are the clear winners at 25ppm/root-khr and 20ppm/root-khr typical, respectively -- about at the 10-1 ratio needed to consider long-term drift insignificant. (The other two parts have long term drift around 50-60ppm/root-khr typical.)
Decoupling everything
The MCP3208 datasheet recommends a minimum 1µF capacitor for decoupling, connected from Vdd to the ground system -- AGND and DGND should be tied back to the same ground system as well. A minimum 10µF/10V ceramic or polymer tantalum bulk decoupler should be used on the board 5V rail as well.
On top of this, the reference should be decoupled as per the datasheet -- this is often 100nF on the output with 100nF on the input in addition to any bulk decoupling capacitance present, but the LTC6655 requires a much larger output capacitor (using the same P/N as the bulk decoupler works), and the X60003 is picky in the opposite direction due to its low power design.
Input drive/buffering/filtering
This, thankfully, isn't hard -- 0.02% accuracy translates to 800µV of maximum input offset, and I can get a couple orders of magnitude better than that with GBWs in the MHz range while running on the single 5V supply available with today's zero-drift and internally trimmed amplifiers. The AD8630 supplies a low-noise auto-zero option, while fast internally trimmed low-offset amps include the OPA4350 and the OPA4192. Either way, the two-pole Sallen and Key low-pass anti-aliasing filter from the MCP3208 datasheet can be used, with the corner frequency set to about 5kHz or so -- other filter designs may work as well.
Power supply and digital interface
The MCP3208's ENOB (effective number of bits) specification is supply dependent -- it performs better with a 5V supply than it does with a 2.7-3.3V one; it also must be running off of 5V to use a 4.096V reference. This raises the problem that the Pi uses 3.3V logic and isn't 5V tolerant, requiring a logic level translation IC such as the TXB0104 -- the A side goes to the Pi while the B side goes to the ADC.
In addition, the 5V supply should be reasonably clean -- a linear regulator should be used to generate it on-board from a higher supply voltage. If no higher supply voltage is available in the application, an existing 5V rail can be used provided a LC decoupling network is used to keep large quantities of digital noise off the ADC and op amp supply rail.
Layout time
There are two keys to an effective mixed-signal layout: partitioning and supply/return layout. I will touch on those in turn.
First, I would split the board layout neatly into two sides -- a digital side and an analog side. All digital traces (the SPI interface, in the case of the MCP3208 you are using) go on the digital side of the board -- this side of the board also contains the logic level translator chip and the I/O connector to the Pi. The analog side of the board contains all the analog traces and circuitry -- the voltage reference goes here, and so do the input filters, input protection, and analog input connectors. The ADC (and filter inductor if you are using 5V from the Pi) is the only component that bridges this gap -- in fact, I would recommend putting a silkscreen line on the board topside to remind myself where the boundary between the two sides is (it will come out L-shaped or slightly zig-zagged as the Vref pin on the MCP3208 sits on the same side as the digital I/O pins).
Note, also, that all the parts I linked are available in coarse pitch SMT packages -- a single-sided layout with the backside as a continuous GND plane is highly recommended if a double-sided board is to be used here. If cost is not an objection, a four-layer board will provide a continuous analog Vdd plane in addition to the ground plane, as well as room for a "power puddle" for the 3.3V logic side of the logic level translator IC. However, there is no need for a ground plane split in this application -- proper routing of the signal traces will keep the return currents where they belong.
ThreePhaseEel
  • 8,858
  • 26
  • 41
