19
I always understood that the point of using smaller capacitors in parallel was to provide low impedance at higher frequencies than the bigger capacitors, because the higher capacitance capacitors 'usually' had larger packages, so the parasitic inductance negated their capacitance from a certain frequency and up.
However, if both caps have the same packaging (0402 in this case), is there any benefit at all?
Peter Mortensen
  • 1,676
apalopohapa
  • 8,419
  • 39
  • The ESR has a lot to do with this also, but I will let someone write a good quality answer for you, to sleep I go. – Kortuk Jan 19 '12 at 04:39
This is a bit of a controversial subject. Some people seem to feel that a capacitor beyond resonance has no benefit for bypassing. Others point out that even past resonance the part is basically just a very small inductor short-circuited to ground and it still has fairly low impedance.
This plot from Murata shows the (magnitude of the) impedance vs. frequency for three different capacitor values in the same package (0402):
This shows that after a high value part (like 0.1 uF) passes resonance, a lower-value part (like 0.01 uF) just barely achieve a lower impedance before it too hits resonance and its behavior becomes dominated by its inductive parasitic, which is basically the same as in the high-value part.
That said, as others have pointed out, the more capacitors you can put in parallel, the more you reduce the series resistance and inductance of the ensemble of parts; so adding more parts is going to help at least a little bit.
Edit:
I should also point out that if you start considering larger values in larger pacakges, say 1 uF in 0805 and 10 uF in an electrolytic A-size package, you can definitely improve the impedance at lower frequencies (below 10 MHz).
The Photon
  • 126,425
  • 159
  • 304
  • Is the image for radial caps with leads? – tyblu Jan 19 '12 at 07:32
  • Now that I looked it up, I can tell you GRM15 is Murata's series name for 0402 parts. – The Photon Jan 19 '12 at 16:40
  • How would a graph of the magnitude of the impedance for a parallel combination of 0.1 and 0.01 compare with the above, bearing in mind that impedance is a complex quantity (impedance changes smoothly in response to frequency; the "knee" in the above plots occurs when the imaginary part of the impedance changes sign). – supercat Jan 19 '12 at 21:57
  • @supercat, To get that you could just get the ESR and ESL values for specific parts you're interested in and simulate them in LTSpice (for example). Murata (as an example) provides SPICE model files for their parts at http://murata.com/products/design_support/netlist/index.html – The Photon Jan 20 '12 at 00:04
    I just wrote a simple program to draw a plot for some hypothetical values, and it seems that depending upon the ESR/ESL values, the parallel combination of caps could in some cases, at some frequencies, yield worse performance than either cap individually. I wonder whether that can actually happen with any combinations of real caps. – supercat Jan 20 '12 at 00:15
    @supercat, see Murata's app note (pages 18-19) for discussion of the "antiresonance" problem, which is pretty much exactly what you described: http://murata.com/products/catalog/pdf/c39e.pdf – The Photon Feb 08 '12 at 23:11
    For future readers: Murata's app note [has moved](http://www.murata.com/~/media/webrenewal/products/emc/emifil/knowhow/basic/chapter02-p4/c39e.ashx?la=en-us) since I made that previous comment. – The Photon Mar 05 '16 at 17:04
Assuming the inductance is essentially fixed for a given package size, the lower value capacitance will have a higher SRF, around which it will decouple more effectively. More than one of each value reduces inductance/ESR to lower impedance around this frequency. Sets of different values provides a low impedance over the entire range needed.
This Xilinx document (xapp623) goes into great detail on the ins and out of decoupling and why different values are used.
To quote a relevant part - they say:
Capacitor Effective Frequency
Every capacitor has a narrow frequency band where it is most effective as a decoupling capacitor. Outside this band, it does have some contribution to the PDS but in general it is much smaller. The frequency bands of some capacitors are wider than others. The ESR of the capacitor determines the quality factor (Q) of the capacitor, which determines the width of the effective frequency band. Tantalum capacitors generally have a very wide effective band, while X7R and X5R chip capacitors, with their lower ESR, generally have a very narrow effective band. The effective frequency band corresponds to the capacitor's resonant frequency. While an ideal capacitor only has a capacitive characteristic, real non-ideal capacitors also have a parasitic inductance ESL and a parasitic resistance ESR. These parasitics act in series to form an RLC circuit (Figure 3). The resonant frequency associated with that RLC circuit is the resonant frequency of the capacitor.
Oli Glaser
  • 54,990
  • 76
  • 147
You are correct: the benefit isn't due to the different values, but in the fact that they are in parallel, effectively halving the lumped ESR and high frequency inductance. As Mr. Johnson [8.2.4] put it:
The best way to get very low inductance is to parallel a lot of small capacitors.
Different ESR values matter for signals or noise above 10MHz; above 100MHz, only package (lead) inductance matters.
This reminds me of another quote, however, repeated by Donald Knuth:
Premature optimization is the root of all evil.
tyblu
  • 8,167
  • 40
  • 70
    Premature optimization is the love of money? – Russell McMahon Jan 19 '12 at 06:25
    @Russel: Over here (.de), we call any components that were added for reasons of premature optimization _Angst-Parts_. These parts are known as a good source of many troubles. They were put there for fear of something, but indeed we should fear these very parts. I guess this makes sense for English speakers, too. (This is not to say that paralleling different values of SMD caps may make sense in some cases, but one should be knowing what one is doing...) – zebonaut Jan 19 '12 at 10:02
    @zebonaut: Sounds like you're saying *"The only thing we have to fear is fear itself"*. – Olin Lathrop Jan 19 '12 at 17:49
Paralleling capacitors can have an undesirable effect due to resonance between the adjacent capacitors. For instance, using the data shown in the comment above, the equivalent inductance in the 0402 case size is approximately 0.4nH. With a spice simulation of a parallel 0.1uF and a 0.01uF capacitor with 0.4nH in series with each capacitor, the two 0402 capacitor packages become parallel resonant at about 60 MHz, with a following series resonance at about 80 MHz. With RF bypassing this may become critical.
Paul Lynas
  • 41
