Taking the circuit from this question: Photodiode driver circuit, shown again as image:
I am now wondering how to calculate the exact needed values for the different resistors and capacitors (in the image placeholder values were used). For the photo diode PD24-01-HS is used (with data sheet here: http://www.ibsg-st-petersburg.com/datasheet/PD/PD24-01-HS.pdf)
From the other question I already know that R2 and the diode are a RC coupled circuit, leading to (if I want to have a frequency of 3 GHz, and assuming that the negative bias voltage in worst case is -3 V) a necessary resistance value for R2 of approximately 40 Ohm. How big should now C2 be? And how big should C1 (which flattens the input voltage) be?
