I would like to light up a 3W LED from Cree having a forward voltage of 2.9 V at 350 mA. It's maximum drive current is 1 A and gives 300 lumens/m2 output. I am considering lighting up this LED using supercapacitors.
The objective is to light the LED for 5 hours.
Based on this objective, I tried to calculate the capacitance required in reverse using the following formula:
(Energy stored in the capacitor)/(Power of the LED) = Time required for the LED to glow)
Additionally, I came to know that If a switching circuit is used, the losses for the supercapacitor charging operation would be less as a resistor dissipates 50 percent of the input energy. If the voltage drop across this circuit is 1 V, then taking this into account as well, I obtain:
\$\frac{\frac12 C V^2 - \frac12 C 1^2}{1.05(P_{led})} = 5\text{ h}\$
As the supercaps are generally rated at 2.7 V, I substitute V to be 2.7 and obtain the capacitance to be 18270 F which is extremely high. I needed to cross verify the theoretical capacitance required to get this LED to glow for 5 hours is right or not.
If I go for a 2.7 V, 500 F supercapacitor, I am obtaining the LED to glow for 30 minutes.
From what I have read about the supercaps, the charging rate is quite high for the supercaps, and assuming that I am generating electricity simultaneusly to charge the supercap and simultaneously light the LED, Would it be feasible?
I am imagining the 2.7 V 500 F supercap as a big tank with an inlet and an outlet. The inlet is quite high because of high charging rate whereas the outlet rate is slower. The inlet rate is 5 W and the outlet rate is given to the 3 W LED.
I am giving a 5 W power input using the right switching circuit to feed it into the supercapacitor. If this is the case, would I be able to instantaneously light this LED. If not how? What would be the right circuit I should implement to use it as a buffer.
