I would like to pass, from the TCL file that is commanding the Diamond tool of Lattice, some options to the Synplify synthesis tool.
E.g.: It is possible to set a value of the VHDL generic at toplevel in the GUI. https://www.doulos.com/knowhow/fpga/Setting_Generics_Parameters_for_Synthesis/
But when saving this project in TCL (save_script test.tcl), this option is not exported to TCL.
Adding the Synplify TCL code in the Lattice TCL file isn't helping.
set_option -hdl_param -set BUILD_VERSION {x"01"}
pnmainc diamond.tcl
invalid command name "set_option"
    while executing
"set_option -hdl_param -set BUILD_VERSION x"01""
    (file "diamond.tcl" line 3)
And the manual not the help in Lattice/TCL isn't revealing anything.
I would like to avoid having another TCL file just for Synplify in my repo.
vermaete
  • 380
    Are you using LSE or Synplify? I'm avoiding a direct call to `pnmainc`. So I'm calling `synthesis -f ` directly. – Paebbels Jul 19 '16 at 08:27
  • @paebbels I'm using Synplify. But I should check with the owner of the code why :-). 'synthesis.exe' is LSE, I assume. – vermaete Jul 19 '16 at 12:00
(I still think it's stupid I can't post that as a comment before 50rep)
Try with the following syntax:
Fluffy
  • 298
