I manage to get the autorouter in Eagle to complete the routing if I use small sizes for the wire and small clearances between wire and pad and wire and wire.
Since I'm making the circuit on a transparency for lazer printers, I'm just curious, what would be the absolute smallest size I could get away with for pads and wires (circuit-board lines) without potentially wrecking the circuit board?
I will be inserting the parts manually (mostly ICs but some LEDs and resistors and capacitors) and then soldering them, and the drill I have that I plan to use is 1/16ths of an inch.
My lazer printer can print up to 600 dpi.
