I'm doing some coding on an STM32F411 board, used the CubeMX & HAL Libraries for laziness.
I'm trying to get the windowed watchdog (WWDG) up & running, and doing the very basic version (non interrupting) works as expected using this sequence of setting up (straight from the HAL/CubeMX):
/* Reset of all peripherals, Initialises the Flash interface and the Systick. */
HAL_Init();
/* Configure the system clock */
SystemClock_Config();
/* Initialise all configured peripherals */
MX_GPIO_Init();
MX_ADC1_Init();
MX_I2C1_Init();
MX_IWDG_Init();
MX_TIM1_Init();
MX_USART6_UART_Init();
MX_USB_OTG_FS_USB_Init();
MX_WWDG_Init(); // Window == count == 0x7F
HAL_WWDG_Refresh(&hwwdg, 0x7F);
HAL_WWDG_Start(&hwwdg);
while(1)
    //main loop stuff
This works as expected (I will narrow the window later), but if I change the code to use the "early wakeup" interrupt function (EWIF) - again, all auto-generated from CubeMX - it instantly fires the interrupt:
HAL_Init();
MX_GPIO_Init();
MX_ADC1_Init();
MX_I2C1_Init();
MX_IWDG_Init();
MX_TIM1_Init();
HAL_WWDG_Start_IT(&hwwdg);
while(1)
    //main loop stuff
The MX_WWDG_Init(); call in this case includes the lines to set NVIC / enable IRQ but is otherwise identical:
void HAL_WWDG_MspInit(WWDG_HandleTypeDef* hwwdg)
  if(hwwdg->Instance==WWDG)
  /* USER CODE BEGIN WWDG_MspInit 0 */
  /* USER CODE END WWDG_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_WWDG_CLK_ENABLE();
    /* Peripheral interrupt init */
   HAL_NVIC_SetPriority(WWDG_IRQn, 0, 0);
   HAL_NVIC_EnableIRQ(WWDG_IRQn);
  /* USER CODE BEGIN WWDG_MspInit 1 */
  /* USER CODE END WWDG_MspInit 1 */
I tried adding __HAL_WWDG_CLEAR_FLAG(hwwdg, WWDG_FLAG_EWIF); just before the __HAL_WWDG_ENABLE_IT(hwwdg, WWDG_IT_EWI); call in HAL_WWDG_Start_IT(&hwwdg); but it makes no difference.
What have I missed here?
John U
  • 7,041
You have to clear both IWDG_SR.EWIF and NVIC pending flag for IWDG interrupt before enabling it:
WWDG->SR = 0;
NVIC_ClearPendingIRQ(WWDG_IRQn);
a3r3
Even I have worked on both IWDG and WWDG of STM32F407 BOARD. I suggest you, use Independent Watchdog Timer(IWDG) instead of WWDG... IWDG timeout is more, and you can configure IWDG prescalar to get the desired timeout..It has a separate clock.
Sagar BN
