Monostable multivibrator
Does this diode help discharge the capacitor once the flip-flop is reset?
Thanks in advanced.
(Image was taken from http://educypedia.karadimov.info/library/oneshots.pdf)
Josh Ito
  • 86
Figure 1. D flip-flop table with the only two conditions of interest highlighted.
Since the D input is permanently high there are only two conditions of interest.
  1. CL going high will set Q.
  2. R going high will reset Q.
R and C in your sample circuit will have a time constant given by $$ \tau = RC = 1M \times 0.1 \mu = 0.1~s $$
  • On each rising edge of CL, Q will turn on for about 0.1 s, R will go high and Q will turn off again.
  • The diode provides a rapid discharge path for C so that the circuit won't be held in RESET mode for the next 0.1 s and is ready to be re-triggered.
  • Maximum pulse detection rate without skipping pulses will be in the order of \$ \frac {1}{\tau} = \frac {1}{0.1} = 10~Hz \$.
Transistor
  • 168,990
  • 186
  • 385
