I have several questions regarding desiccant and electronic components:
Is there a rule of thumb on how much desiccant, let's say silica gel, to use per volume unit or per package area unit?
Must a package be very well isolated for the desiccant to do any good?
What is the lifetime of some desiccants at room temperature with a humidity of 50-55%?
Naturally, different electronic devices have different sensitivity to moisture. The type of devices I'm talking about here are ICs like operational amplifiers, microcontrollers and memories.
skrrgwasme
  • 828
  • 32
    Yes, your package needs to be sealed to allow the desiccant to do its job with an uncontrolled/unacceptable external atmosphere. – user2943160 Jul 07 '16 at 14:16
  • If you are sealing the packaging, and humidity control is critical, using (dry) nitrogen *might* be an option. – Andrew Morton Jul 07 '16 at 19:15
There are actually a lot of variables that go into figuring out how to properly package, ship, and store electronic devices. The Joint Electron Device Engineering Council (JEDEC) maintains a standard for specifying these procedures:
J-STD-003B.1: http://www.jedec.org/sites/default/files/docs/jstd033b01.pdf
The standard provides the following equation to decide how much desiccant to use:
When the desiccant capacity at 10% RH and 25°C is known the following equation should be
used:
U = (0.304 * M * WVTR * A)/D
where:
    U = Amount of desiccant in UNITS*
    M = Shelf life desired in months
    WVTR = Water vapor transmission rate in grams/m2 (grams/100 in2) in 24 hrs
    A = Total exposed surface area of the MBB in square meters (square inches)
    D = The amount of water in grams, that a UNIT of desiccant will absorb at 10% RH and
        25°C
*Note from the standard:
For comparison between various desiccant types, military specifications adopted the ‘‘UNIT’’ as the basic unit of measure of quantity for desiccant material. A UNIT of desiccant is defined as the amount that will absorb a minimum of 2.85 g of water vapor at 20% RH and 25°C
You should review this standard carefully when making packaging decisions, because there are a lot of variables involved in choosing correct packaging. In addition to the variables in the above equation, things like package size, anticipated humidity exposure, reflow bake times, and more need to be considered.
And yes, the package must be sealed for any of this to be applicable.
Although this industry standard covers most cases, you should also be aware of standards that govern your device's particular application. For example, the U.S. Department of Defense has standards MIL-PRF-81705 and MIL-D-3464 that describe their requirements. These two particular documents are, as far as I know, adhered to by J-STD-003B.1, but there may be others in your particular industry that J-STD-003B.1 is not compliant with.
skrrgwasme
  • 828
  • 32
