The long story short:
Is there any chance that an asynchronous motor with a run (or start?) capacitor fails to run backwards when the capacitor ages and loses a significant portion of its rated capacitance?
The somewhat longer story:
An asynchronous motor using a motor capacitor within a single-phase device is controlled by two triacs. The motor itself has three wires, let's call them L1, L2 and N. There's a capacitor between L1 and L2. The two triacs power either L1 or L2 and thereby allow forward or backward rotation of the motor - at least that's what I'm assuming.
Simplified schematic (switch symbols are really triacs):
C is labeled with 4 µF, but it tests out around 2.2 µF (checked by using a RC network with a 100 Ω resistor and finding the corner frequency with a scope and a function generator - in lack of a DMM with a C range...). So yes, C is indeed bad and it's a good idea to replace it... As long as that's in accordance with what I assume concerning the direction of the motor...
Sometimes, it seems that the motor runs forward when it should be running backward, and my guess is that this may be caused by a low capacitance in the motor's run capacitor.
The even longer story, with some background info:
I'm in the process of troubleshooting my dishwasher. My particular model has one pump motor with two wheels. When it runs forward, it pumps water into the interior, happily splish-splashing and rinsing the dishes. When it runs backwards, it pumps the water out of the dishwasher and into the sewer. After having watched it work and fail for a while now, I get the feeling that sometimes, the motor fails to run in the "dump" direction and keeps moving in the "clean" direction, often in a step of the program when it switches quite fast from "clean" (forward) to "dump" (backward). Then, some blinking LEDs on the panel say that something has failed and it stops working. The blink pattern is not in the user's manual, and it's different from other service error messages (like "water in the bottom, micro-switch above floating styrofoam 'brick' has detected leakage", and I made sure there's no leak). I can rule out pretty much everything else, and the only remaining explanation for the problem is the motor's failure to run in reverse direction (dump) every once in a while. It seems like the level switch still tells the controller that water is present (and there is), when the controller assumes that the pump should have dumped the water and, as a consequence, runs into a time-out. Is there any chance that replacing the motor's run capacitor will fix the problem?
Yes, the motivation of this question is that I'm trying to fix a household appliance. But... Asynchronous motors on single-phase systems with motor capacitors are a very common occurrence, and the question is really with a quite general focus... Once the elliptical field created by the capacitor becomes too narrow, couldn't it be that the motor starts off in the wrong direction? Even more so when it's maybe not a run capacitor but a start capacitor? I might still edit info about my particular make and model of dishwasher into the question at a later point, but as it stands, the question is relevant for any equipment with a motor capacitor and a motor that should be able to run forward and backward.
Once, I had to replace a capacitor next to the motor in a washing machine, but there, the problem was not the direction. It just didn't have enough torque once the laundry got wet and heavy in the drum. Here, the pump's torque still seems to be OK, but it appears it sometimes fails to start in the right direction...
zebonaut
  • 18,170
  • 60
  • Can you measure the capacitor value and compare against the rating? The capacitor is what creates the lag for what I suppose is your two phase motor in order to make it run backwards. – winny Jul 02 '16 at 20:32
  • @winny I'll add this info once i have it. Do you think my general guess my be true, i.e. depending on whether you connect L1 or L2 to L, the motor gets either L1, C-L2 (lag via C on L2), N as a somewhat elliptical field, or, respectively, L2, C-L1 (lag via C on L1), N, and this would decide if it runs forward or backward? – zebonaut Jul 02 '16 at 20:38
    Zebomaut - your understanding is correct. But even a weak capacitor should bias toward the correct direction. The cap could be completely dead, at which point the direction would be somewhat random (but there might be a mechanical bias toward the direction that it fails in). Note that it doesn't seem to fail when it wants to wash. Another possibility is that one triac is (mis) firing when it shouldn't. – Mark Jul 02 '16 at 21:00
  • @Mark I have already worried about the triacs, too. What makes me suspect the capacitor is to blame is this: When the triacs (mis)fire, wouldn't they self-destruct quite quickly by shorting out the third phase that the capacitor and windings (artificially) create? As far as I understand the setup, it is very important that only one of the two triacs be on at any given time, and there even should be some extended break-before-make dead-time? – zebonaut Jul 02 '16 at 21:06
    There are two windings in the motor, and both are capable of sustaining the full current that the AC line produces. What the capacitor does is simply cause one winding to lag (and that winding might produce reduced torque compared to the other). If both windings were connected to the AC line simultaneously, there would be no short. There would simply be no preferred direction and maybe a little more power. – Mark Jul 02 '16 at 21:13
  • You've too many windings on the motor sketch. Remove the one in parallel with the capacitor. I agree with @Mark that two triacs on simultaneously shouldn't cause any problem other than some increase in power. – Transistor Jul 03 '16 at 08:36
  • @transistor Thanks, image fixed. You're correct, the schematic is now similar to those I found about single-phase asynchronous motors. – zebonaut Jul 03 '16 at 08:45
    4 uF -> 800 Ω at 50 Hz. If you remove the capacitor and wire it in series with a 60 W filament bulb (if you're still allowed have them in Deutschland) you should see the lamp glow fairly brightly. The resistance of a 60 W lamp will also be about 800 Ω. Since the lamp is resistive it's voltage will be at right angles to the capacitor voltage on a vector diagram making a right-angled triangle with equal sides. The diagonal is 230V so the voltage across the lamp should be about \$ 230 \frac {1}{\sqrt {2}} \approx 160 V \$. That will give you an idea if the capacitor is OK. – Transistor Jul 03 '16 at 09:04
    @transistor Cool, yet another light bulb trick... The cap has a bit over 2 µF (but I used another hack to measure it, see edit above). – zebonaut Jul 03 '16 at 09:44
    If it's paper-in-oil, or most foil caps, I can't see any mechanism for it to lose its capacitance. And at 4uF it's unlikely to be electrolytic. I'd suspect a problem with the measurement rather than the cap, unless a DC resistance measurement shows leakage current. Switching direction, however, requires a complete stop. If the motor is still rotating, it will continue in the same direction. So I'd suspect a failure or wear in some mechanical part like a friction brake or a clutch, or some grease where it shouldn't be (or vice versa) –  Jul 03 '16 at 10:48
    @BrianDrummond The washing machine I mentioned above had a film capacitor (like the dishwasher now, but it hat 14 µF). It had degraded to 5 µF over time. Of course, I took it apart and looked at the film: What used to be a good layer of aluminum deposit on the film looked like thousands of little craters. I guess that every time the motor was turned off, the freewheeling spike may have caused a little spark in the film cap, and because of self-healing, the show went on until the capacitance (areas of the conductive layer on the foils) became too small. Replacing the cap brought back the torque – zebonaut Jul 03 '16 at 17:06
  • @zebonaut ; Nice investigation, and an interesting difference between film caps and the foil caps I was expecting. This equipment is relatively new (less than 30 years old) then? –  Jul 03 '16 at 19:33
  • Zebonaut on a question with a comment on a deleted answer by you (so I could not there flag you) I wrote the comment below. This concerns the IMPROPER use of a TL431 - which happens to work well in practice :-). | Question is: https://electronics.stackexchange.com/questions/7038/tl431-as-a-comparator ... – Russell McMahon Dec 30 '19 at 09:36
  • You wrote: Be careful when allowing "Cathode" to go lower than "Ref": The diagram alone says that this might work, but remember that the internal reference needs at least 2.5 V (and 1 mA) to work, and both are supplied through the "Cathode" pin. Also remember that the internal opamp "triangle" will try to keep both of its inputs at the same voltage, i.e. 2.5 V. Therefore, the "Cathode" should, in a real application, remain at or above the voltage at the "Ref" pin, i.e. >= 2.5 V. The LT1431 has separate pins for the supply and the open collector output and can go lower than "Ref" at "Cathode". – Russell McMahon Dec 30 '19 at 09:37
  • I commented: 9 years on :-). Re Zebonauts comment on TL431 Cathode voltage. Vcathode_min is indeed usually specified as Vref. In practice (based on extensive experiments with a range of brands of TL431 and TLV431) I've found that Vcathode can fall to slightly above Vref-1_diode-drop with "reasonable safety". This is of course an out of spec condition and if used in a designed design the designer needs to take responsibility for any consequences. | This "feature" can be quite useful. | If Vcathode falls to under somewhat above Vref-1-diode-drop Vref will be loaded and regulation fails. – Russell McMahon Dec 30 '19 at 09:37
6 Answers6
If the switching cycle is too short, the motor will run in the same direction. there should be a brief interlude between running forward and backward. I have seen this on other equipment, if the switch is moved to fast and the motor is still turning, it will continue to run in the same direction.
Tim Shrum
  • This can definitely happen with something manually reversed - especially something with a lot of inertia like a lathe (which is part of why 3-phase motors are strongly preferred there). But I suspect the motor reverse on a dishwasher is not manually selected, but rather an automatic part of the cycle, and the timing of any gap probably hasn't changed. Capacitors can indeed fail with age. – Chris Stratton Sep 17 '16 at 09:19
  • I've seen this - see my previous comment. – Kevin White Nov 19 '16 at 00:42
Tim Shrum got it right. If the direction reversal is instantaneous, the motor will not reverse. It needs to stop in between. Is the motor fully loaded (pumping water) when running forward, at the time of the switchover? If it is freewheeling, it may have too much inertia and not enough load to stop quickly so it can react properly to the reversal.
spamsink
  • 131
Perhaps the commander of your dishwashing machine is malfunctioning?
The capacitor in single-phase motor is just starting role. What I mean is that the condenser coil with artificial help to establish a phase difference. If the capacitor has leakage, the single phase motor can't be started. (not forward or reverse rotation) But for changing rotation in single phase motors, the switch or triac changes direction instead of main and auxiliary winding. For this reason there are three wires. Your schematic diagram is correct if the switch was connected to L1.
When the motor rotates to the right (main winding) but the switch is connected to L2, the motor rotates to the left and the (auxiliary winding) capacitor is the starter. This has nothing to do with the direction of rotation.
Voltage Spike
  • 75,799
  • 80
  • 208
mass1351
  • I expect that the motor uses the capacitor for run not just starting. My treadmill uses a similar arrangement for elevation. A long time ago I repaired a magnetic crack detector that had a motorized Variac transformer that suffered from a similar problem - it was supposed rotate up to a maximum value then reverse back to zero - often it would fail to reverse and would carry on forward until it jammed on the end-stops. – Kevin White Nov 19 '16 at 00:42
OK, this might not be the answer to your question, but it is just an idea. If you think the capacitor is the reason it won't run backwards, then why does it still run forwards just fine? Also, if you want to see the effect of the capacitor on the motor's operation, then remove the capacitor and see what happens. If it doesn't run at all, then the capacitor is critical. If it still runs, but not as well, then the capacitor is not as critical of a component. Also, it could be the control circuit in the dishwasher. Maybe it is not working properly and is not supply a "reversing power" of sorts to make the motor go backwards.
Doctor Circuit
  • 154
Since a single phase motor has a start winding & a run winding the motor can be reversed by reversing the start windings. This has nothing to do with the capacitor since it is only used to temporarily sync the start & run windings together. Once the motor is at 60-70% of rated speed a centrifugal switch disconnects the start winding. This switching is done through the timer control & is used in many applications like dishwashers (wash/drain) & washing machines Wash/spin(drain). These motors are called capacitor start/induction run.
-4
If the fault is due to the hardware one of them is definitely faulty.
Voltage Spike
  • 75,799
  • 80
  • 208
