I am trying to writte a small note for our staff when they purchase components. Quite often some resistors, capacitor, inductor, diode and transistor (NPN and MOSFTET) may not be availble on the market.
For this reason swapping or replacing some components might make sense after the engineering to review those swap proposal. I have already roughly established how to replace or swap capacitor based on several criterias like this:
CAPACITOR (C)
Brand: swapable
Value (F): should be the same
Rating (V): take the same or you can take higher value
Tolerance (%): take the same or lower %
Temperature range : same or bigger range including the current range
Footprint: as to be the same otherwise can not solder on pcb
ESR: ??? (I didn't find out this)
RESISTOR (R)
Brand: Swapable
Value (Ohm): should be the same
Rating (W): take the same or you can take higher value
etc..
I am trying to establish the same format for D, L, Q, S, J
What parameters seems the more obvious for you for those 5 other components mentionned above ?
Thank you very much for your help
for line break. – Curd Jul 01 '16 at 11:05
