If I route a 433 MHz AC-coupled RF microstrip trace out of an MMIC such that it's referenced to a Power plane rather than a Ground plane, will that have a significant effect on the impedance of the trace?
I'm designing a 4-layer PCB with a Signal-Ground-Power-Signal stackup which has MMICs on both sides (this amplifier being one example). This makes me want to run microstrip on the bottom such that it's referenced to Power rather than to Ground. I'm aware that this is OK for digital signals (this page from Henry Ott being what finally convinced me of that), and I've read through Microstrip over power plane, but there are a few things that make me leery of blindly applying those conclusions to this situation.
1) This isn't a push-pull driver like the ones in the paper, it's a Class C amplifier (some of the others are Class A). This means it's not symmetric and if I understand right there's likely to be significant inductance from power to collector when compared to emitter to ground.
2) MMICs have a nice big flat low-inductance ground connection through their thermal pad, but typically only a few pins for power. I can only assume any microstrip on-die will be referenced to that ground plane, which I'd imagine would create a discontinuity when transitioning to the PCB microstrip.
3) Eventually this all runs into a coaxial connector whose shield is connected to ground. Unless I connected shield to power (which seems like a terrible idea), wouldn't that create a pretty significant discontinuity as well?
Can someone clarify this for me, ideally with a level of specificity comparable to that Henry Ott paper? I'd really appreciate it!
