-1
I'm trying to repair my headphones with a broken jack. I just purchased a replacement TRRS jack, and now my problem is knowing the function of the five different wires in my earbuds. How can I use a multimeter to do this? Thank you in advance.
Touching the ohmmeter to the pair of wires going to each earbud and ground should cause an audible pop and show low impedance. The remaining non-ground wire would be for mic. See Fixing a headset, TRRS
stark
  • 171
  • I just tried this and I can't seem to hear any audible noise. Does one lead need to be touching the ground wire and the other lead a different wire? I did this for each wire with no luck. Could it be the setting my Ohm Meter is on? – Brandon R. Jun 27 '16 at 22:41
  • It is the current through the speaker that causes a pop, so you need one lead on the audio and the other on the return. Depending on wiring, the return may be common or separate for the two sides. – stark Jun 28 '16 at 00:40
