I have read somewhere that the gate capacitance (Cgs, Cgd) of a MOSFET is calculated as below:
Strong inversion:
Cgs=(2/3)Cox.W.L + Cov
Non-saturated:
Cgs=Cgd=(1/2)Cox.W.L + Cov
where Cov is overlap capacitance.
Could anyone explain where the formulas come from?
ocrdu
  • 8,705
  • 30
  • 42
emnha
  • 1,547
  • 84
    whatever assumptions that were used for those equations, I personally would not agree with. where did you get those? – b degnan Jun 27 '16 at 02:08
  • I don't remember where I read it. Could you give your alternative formulas? – emnha Jun 27 '16 at 02:17
Reading in the tea leaves here, I'd surmise that for the case of:
your equation 2)\$C_{gs}=C_{gd}=\frac{1}{2}C_{ox}WL + C_{ov}\$
They are taking the gate to channel capacitance and dividing equally between the S & D.
In the case of:
your equation 1)\$C_{gs}=\frac{2}{3}C_{ox}WL + C_{ov}\$
It looks like they are lumping the pinched off part of the channel which is attached to the source.
In your equation #2, while this is not strictly wrong, it is the wrong way to look at it. It would be best to think in terms of gate to channel.
In your equation #1, that might only hold true in one particular channel condition. Once the channel pinches off the drain doesn't under go massive capacitance changes.
I'd be suspicious.
From the book "Operation and modelling of the MOS transistor" by Yannis Tsividis (recommended reading !!) the following equations from section 8.3.2 (page 391 in the 2nd edition). For strong inversion:
$$ C_{gs} = C_{ox} \dfrac{2(1+2\eta)}{3(1+\eta)^2} $$
$$ C_{gd} = C_{ox} \dfrac{2(\eta^2 + 2\eta)}{3(1+\eta)^2} $$
\$ \eta = \$ degree of non-saturation. With \$ \eta = 1\$ at \$V_{ds}=0\$.
So in the case with the channel fully pinched off \$ \eta = 0\$. We get the case of your equation #1.
placeholder
  • 29,982
  • 63
  • 110
    I haven't read Yannis book, but I'm going to have to ask him why he used those derivations. Assuming that pinchoff is a 1/3rd of the channel is just weird. It basically says that if you have bulk and source connected, you start with \$WLC_{ox}/2\$ for source and drain overlap and then as you approach saturation the source capacitance increases, and the drain and gate capacitance decrease, giving the \$2/3\$. The behavior is fine qualitatively, but I've never seen pinchoff to be that pretty. – b degnan Jun 27 '16 at 13:01
    @bdegnan I fully agree with the 1/3 aspect. I had written that up as being silly, doubled checked in yannis' book and then edited. – placeholder Jun 27 '16 at 13:12
    device physics is a complex beast, so if 1/3, 1/2 or 2/3 helps people understand what's going on well, I'm all for it. Unless you are in the modeling field, it probably really doesn't matter that much. Good reading of the tea leaves btw, I couldn't figure out where the original equations came from until I saw your answer. – b degnan Jun 27 '16 at 13:45
  • Thank you. Could you explain why Cgs + Cgd is not equal to Cox with any eta? – emnha Jul 01 '16 at 07:12
  • @anhnha because of pinchoff, look at what happens to the channels' inversion layer when you support lateral drift. – placeholder Jul 01 '16 at 14:11
Your equations are approximations to the capacitance seen between G-D and G-S of a mosfet in different regions of operation and they are derived based on the physical characteristics of the mosfet. Keep in mind that the physical mosfet is a symmetric device. In the case of N-MOS, the terminal with a lower voltage is called the source (since it sources the charge carriers i.e electrons) and the terminal at the higher voltage is called the drain. Now taking as an approximation, the GATE-OXIDE-CHANNEL form a capacitor with capacitance \$C_g=C_{ox}\cdot W\cdot L\$, if you look at the channel at different regions of operation you can easily derive the approximations.
Cutoff region: There is no channel, so the gate capacitance is seen across G-B $$C_{gb}=C_{ox}\cdot W\cdot L+2C_{ov}$$ notice 2 overlap capacitances are seen
Linear/Triode region: A uniform channel is formed, isolating the Gate from Bulk, so we can approximate that the capacitance is evenly shared between the source and drain $$C_{gs}=C_{gd}=\frac 1 2 C_{ox}\cdot W\cdot L+C_{ov}$$ now 1 overlap capacitance for each terminal
Saturation region: The channel is triangular and pinched off at the drain we approximate that 2/3 of the capacitance is between gate and source and no capacitance between gate and drain $$C_{gd}=C_{ov}, C_{gs}=\frac 2 3 C_{ox}\cdot W\cdot L+C_{ov}$$ you could assume \$C_{gd}=0\$ to simplify your calculations.
Important Note that these are mere approximations to the actual capacitance and are only good for developing intuition and performing quick "back of the envelope" calculations for designers.
Fiebbo
  • 145
The factor of 2/3 comes from looking at the spatially-resolved gradual-channel model. There (at VDsat) the inversion-layer density varies as the square-root of the distance measured from the drain. Integrate the density to get the total charge and you get Q = 2/3 Cox W L Vgst. Cgs=dQ/dVg and you get the quoted result. Of course this is only as good as the gradual-channel (GC) approximation. If you swear by GC you'll believe it. If you swear at GC, you'll have other ideas. Tsividis's analysis appears to be completely based on Brew's charge-sheet model. This is still a GC model: the formulation implicitly relocates the drain to the classical pinch-off point, entirely distorting the electrostatics of the drain region.
BillF
  • 311
  • I think you need to work a bit on presentation. There's potentially good stuff here, but a bit compact. – pipe Apr 19 '17 at 23:48
  • @BillF can you elaborate and explain more – beta_me me_beta May 23 '21 at 11:19
    The algebra required to demonstrate the 2/3 factor is a bit involved, and getting a real understanding of the electric field patterns in a MOSFET requires looking at a few plots. These are all in a digital textbook that I am developing. At the moment I cannot post this material publicly, but if you send me an email I will extract the relevant chapters and send them to you. I am at the University of Texas at Dallas and if you google "understanding semiconductor devices" site:utdallas.edu, you should have little trouble identifying me. – BillF May 24 '21 at 14:56
This might help you out.
Reference:
B. Razavi, Design of Analog CMOS Integrated Circuits, McGraw-Hill, Boston, 2001
ocrdu
  • 8,705
  • 30
  • 42
