I've got some spare phone batteries and I'd like to be able to charge them without a phone. However, it seems like I can only charge it with my phone: I attach + pin to 5V DC, - pin to GND, the third, middle pin disconnected. My battery charges only if it's in a telephone, why? How can I charge it? Do I need to connect somethin to the middle pin? The battery is Samsung Galaxy Mini 2's own.
1The battery in your cell phone is a Lithium polymer type battery. Please research lithium polymer (or lithium ion) battery charging for more information. After you do some research, you may want to ask a more specific question. – user57037 Jun 25 '16 at 17:43
It says Li-ion, 3.7V, and I've already done some researches. However, I found only people saying to connect + to +, - to -. I don't know what to do with the third (BSI, or thermistor) pin, even though I found no evidence I should use it – Oxen Eknat Jun 25 '16 at 17:49
2Li-ion and Li-polymer = same thing for charge purposes. You cannot charge a Li battery using 5V. You need to charge it using current and voltage limiting and have some method for automatically terminating charge when charge current drops below low threshold (0.1C or something similar). If you had done research, you would have learned at least those basic facts, I think. – user57037 Jun 25 '16 at 18:04
3There is FAR more to charging Li-ion than "connect + to +, - to -". Many kinds of batteries (particularly Li-ion) require special measures to closely monitor the amount of current being injected into the battery for charging, the state of the charge, the temperature of the battery, etc. You must use a circuit specifically designed for charging Li-ion batteries or risk catastrophic failure (file or explosion). You are putting yourself at considerable danger unless you do much more through research into charging Li-ion. – Richard Crowley Jun 25 '16 at 18:04
I knew about risks, but I found people saying you could just do what I said above. It's like when they say you need to be grounded when building a pc but you can actually build it anyways (and lot of people do that). I think I'll buy a protection circuit to be safe, thanks. – Oxen Eknat Jun 25 '16 at 18:11
2Those batteries are Lithium, charging them on their own could cause them to explode, please research the correct charging of a Lithium battery, what phone are these batteries from? for example iPhone batteries come with over charging protection, but you should never charge a Lipo on its own, with out a proper charger. – Alex Jun 25 '16 at 18:35
You can only use a Li-ion charger. If you try to charge it with 5V then the protection circuit in the cell will trigger and disable charging. The safety warnings should not be ignored since Li-ion cells are highly volatile (e.g. recently [a vaper lost an eye](http://www.candlepowerforums.com/vb/showthread.php?419453-Vaper-loses-an-eye-from-e-cig-explosion) from a Li-ion explosion). ESD protection is a poor analogy. – Bill Dubuque Jun 25 '16 at 20:21
Is there any reason you aren't using [the device designed for this purpose](https://www.amazon.com/Keple-Battery-GT-S6500-GT-S6102-Smartphone/dp/B01E7AP3FA/)? [(lower price)](https://www.amazon.com/Generic-Charger-Universal-Retail-Packaging/dp/B00IWSNKA4) – Ben Voigt Jun 25 '16 at 22:25
Just buy an external/spare battery charger. There are ones made for your battery, and universal ones. Quality varies obviously. http://i.stack.imgur.com/HxGsv.jpg – Passerby Jun 25 '16 at 22:26
Note that you can find universal cell phone battery charges for under $2 on eBay, e.g. see the link in [this answer.](http://electronics.stackexchange.com/a/146175/40673) – Bill Dubuque Jun 25 '16 at 22:40
The temperature sense pin only needs to connected if you want to sense the battery temperature, otherwise you can leave it unconnected. There are lots of small Li-Ion/LiPo battery chargers that run from USB on *a popular auction website* – Sam Jun 26 '16 at 00:30
A safe way is to buy a duplicate phone, but with no network contract. It will not be usable as a cell-phone, but it will charge duplicate batteries safely. Usually a green LED comes on when the battery is charged.
You can take it out and put it into a "charged" bin where it will hold its charge for weeks or months, allowing you to charge up more than one spare battery safely. If your phone offers a 'charge percentage' display option, turn it ON.
There are many cheap chargers on ebay which contain the appropriate charging circuit to charge your battery correctly (many will even use the correct polarity whichever way around you connect it).
It is possible to charge the battery with 5V directly but it is not advised as it is very possible to damage the battery or even cause fires or explosions. (I have done it in an emergency and was sure to only apply a small amount of the battery's capacity).
- 176
- 1
I have designed several products incorporating lithium ion batteries and chargers. Part of the qualification involves abusive tests of the battery. Generally, charging batteries in a mildly abusive manner (for example charge to 4.3V or 4.4V instead of 4.2, or charge at very high rate) do not result in immediate damage to the cell. Also, most battery packs have built-in battery protection which will shut down charge current at 4.3 or 4.4V. What this means is that what you are doing may seem to be working fine. But it is still not a good idea. I hope you will trust my opinion and advice, since I have nothing to sell to you, and have no vested interest.
Do not charge your lithium ion or lithium polymer batteries in an uncontrolled fashion. During charging, the current needs to be controlled to something like 1C or 0.5C until the voltage reaches 4.2V. Then hold at 4.2V. At that point, the current will taper down. When it gets to something like 0.1C, charging must be halted. If the cell does not reach 0.1C (or similar limit) within a reasonable time, (say 2X or 3X the normal charge time) then the charge must be halted. This latter case would be a sign that the battery is at the end of its service life. You may wish to consider discarding a battery that does not taper to 0.1C after a long time.
If you fail to follow this program, the cycle life of the battery will be reduced (which is a good enough reason not to do it), and the probability of catastrophic failure will increase, although it is hard to say by how much.
I know some people say "lithium batteries explode when you over-charge them." Then you try it once, and it doesn't explode, so you think they are just full of BS. The reality is that over-charging can lead to irreversible chemical changes inside the battery that increase the chances of dangerous failures. It is not a recommended practice, and the faster you charge the battery, or the higher you over-charge it, voltage-wise, the larger the chance of problems. Just for completeness, I will also mention that lithium cells should not be charged at all at temperatures colder than 0C, or warmer than around 55C. Fast charging at temperatures below 0C is especially harmful to the cell.
A lot of this information is available in the JEITA document on laptop batteries (URL below). If the link is dead just google for JEITA charging and you will find it. Full title is: "A Guide to the Safe Use of Secondary Lithium Ion Batteries in Notebook-type Personal Computers."
http://home.jeita.or.jp/page_file/20110517171451_cub9MvYFEh.pdf
- 28,915
- 1
- 28
- 81
