Introduction and General Question: Scalability
I have assembled very simple circuitry to successfully control one RGB LED strip. I have also managed to improve slightly its yield. However, when I try to scale to a larger installation with more LEDs and more light, I fail. These are the steps I have undertaken and the circuitry I used. I am just a hobbyist, time for a real engineer to teach me a lesson and explain what I am missing to scale this to more than a single strip?
Circuitry Overview
  • Three channels, one for each color
  • Each channel is controlled by a GPIO pin on the Raspberry Pi, directly connected to the gate of a MOSFET
  • The drain of each MOSFET is connected directly to one color channel on the LED strip
  • the source of each MOSFET is connected to ground
  • the +12 terminal on the LED strip is connected directly to the +12V power supply
  • the ground of the power supply is connected to ground
  • the ground of the Raspberry Pi is connected to the same ground
Very simple. Too good to be true? It works, I can dim the light and control its color, but...
Resulting Current Draw and Luminosity
As a reference, powering a single strip directly measured 61.3W draw at the wall.
Powering two strips directly measured 99.4W. Why a 18.9% loss and can it be mitigated?
With the single strip controlled and the controller set to ON, measured 47.7W. Why a 22.2% loss and can it be mitigated?
With two strips controlled and the controller set to ON, measured 66.9W. That's an even bigger loss of 29.9% compared to the single strip controlled and a staggering 58.49% compared to the single strip direct.
I have not measured the resulting luminosity and the relationship is not linear, but the difference is visible enough to give it a thought and see if there are improvements available.
Main Questions
  • Are such losses normal?
  • What are the explanations?
  • Can I (at least partially) mitigate?
Materials and Specific Questions
Power Supply
For this experiment, I am powering the Raspberry Pi independently and there is no issue with that 5v wall wart. Eventually, I will want to connect it to the project's main power supply's 5v, but that's not at issue now.
The project's main power supply was pulled in perfect working conditions from a DELL Vostro PC. On its sticker, I read, amongst others, the following ratings:
  • +12VA 16A max (so 192W)
  • +12VB 18A max (so 216W)
I have used the +12v from the video card connector as well as the +12v from the hard disk connector, for the exactly same results. The only really scalable scenario is when I power four strips (which is the goal) directly, two on the video card connector and two on the hard disk connector. The result is, as expected, approximately 2x the current draw of powering just two strips directly off either one of the connectors.
  • Does the power supply have two rails (A and B) ?
  • How do I know which rail I am using ?
  • Does it make any difference in this context ?
5050RGB LED Strips
Cheap Chinese stuff off eBay. Can't trust its specs. A similar one has been the subject of this question. It is 5m / 16ft long, with a total of 300 LEDs. I measured the power draw of a strip (not on the project's power supply, hence these wattages do not compare with the others in this question):
  • 38.2W when feeding it from one end
  • 45.4W when feeding it from both ends
  • 45.5W when feeding it from the middle
I opted to feed each strip from the middle and soldered 4 wires accordingly.
Wiring and Breadboard
I am aware of voltage drop and used a calculator. Two strips are at about 8m from the power supply and I use AWG 14 wire, except the last few cm of soldered wires that are probably AWG 20. I probably over-dimensioned the wire. There is no visible difference between connecting close to the power supply or adding the 8m wire, and there is no excessive heat build up at soldered, thinner wires after a few hours of operation.
The MOSFETs are currently on a breadboard and there is a little issue with overheating on the connection of the power supply's ground cable to the breadboard, due to the fact that the breadboard connections are very thin pins. Could the breadboard's thin ground connection be one reason for the observed loss, and would it be mitigated once the ground connection is thicker?
MOSFETs
IRFZ44N. The heatsinks become warm but are still touchable after three hours of continuous operation at maximum output. I have used these because I had them lying around from an older, Arduino-based project. They seem to be doing the job.
Are there alternative MOSFETs that are more efficient for driving this level of power? Or a different, more efficient circuitry? I apologize for the very broad and open question. I am no engineer, just a hobbyist open and eager to learn from real engineers.
Raspberry Pi
Nothing special to report. Unless I am missing something really big, I can't believe that it has any influence on the power draw?
Updates
I implemented the accepted solution, using BC547B instead of 2N3904. I also powered the Raspberry Pi from the stand-by 5v on the ATX power supply. The installation is more luminous and the draw at the wall closer to expectation:
  • Raspberry Pi only (power supply in stand-by): 3W
  • Power supply turned on by the Raspberry Pi, no load (still waiting for a 5v 1A strip that will light inside the cabinet): 13.7w
  • one LED strip, full power: 56.0W
  • two LED strips at 50% power: 48.7W
  • two LED strips at 100% power: 84.0W
I have yet to connect the third and fourth strip, and to make a long run test to check for heat, but the experiment is conclusive and the lighting system works.
Yuv
  • 123
  • Schematic? Sure it's simple but still. – Passerby Jun 25 '16 at 02:53
    Oh, and the Irfz44N is not a logic level mosfet. It will barely turn on at 3.3V logic, so that's 95% of the problem. – Passerby Jun 25 '16 at 02:56
  • thanks for the quick reply, @Passerby. How can I draw a schematic? I am new to electronics.stackexchange.com and I have no idea whether that is possible. What alternative to IRFZ44N would you suggest? – Yuv Jun 25 '16 at 03:00
    There is a schematic tool on the edit section. As for a replacement, I don't know, any 3.3V logic level n mosfet should work at your levels, or a mosfet driver circuit which could be a simple npn transistor and a few resistors. – Passerby Jun 25 '16 at 03:03
  • @Passerby: I am not sure my schematic is correct, but I learned the first steps of a drawing tool. I googled for "logic level n mosfet" and learned a little bit about that subject, but I have no clue yet how to choose one? – Yuv Jun 25 '16 at 03:27
  • There are entire books on that. But the important one is finding one that can pass X amps at Y gate voltage. In this case 4+ Amps at 3V. Or I'll link to another identical question where I provided a simple npn based mosfet driver circuit so you can use the existing mosfets, tomorrow – Passerby Jun 25 '16 at 03:33
  • And your schematic is correct, only missing a few labels. So my initial guess is correct. Those mosfets just don't turn on ***all the way*** at 3.3V at their gate. They are only slightly on, so they have a higher resistance at the Drain Source than your led strips like. – Passerby Jun 25 '16 at 03:37
  • Glad to see the update. Cheers. – Passerby Jul 06 '16 at 08:19
  • I tried your circuit for my 12v led strip ad it works great but it doesn't work with cob led lights it flickers. I am using cob respective power supply which is 7v-10v @ 250ma. Your circuit works when I remove 10k resistor but transistor 2n222 is getting hot can you suggest the best solution to dim my cob led – venkat reddy Jun 04 '20 at 17:11
You may see that the mosfet won't turn on all the way. The datasheet shows that it's Voltage Gate - Source Threshold (VGS(TH)) is 3V typical, 4V max. Meaning that it may barely work at the RPI'S 3.3V level. That Mosfet is not well suited for 3.3V logic level applications. At 3.3V, the FET won't even pass fractions of an Amp.
The RPI's 3.3V logic isn't turning the Mosfet on all the way.
If you want to stick to that mosfet, you could use a simple NPN transistor as a driver. A 2n3904 or 2n2222 or any similar. It's not critical, it's just a switch. Logic will be reversed, so on the RPi, A logic High/3.3V will turn the leds OFF.
The RPI's ground and the 12V supply's ground need to be tied together as well. If anything, make sure you have that happening right now as that's a common mistake. It could be as simple as not having connected it right.
Otherwise, you want a "Logic Level Mosfet", one that has a VGS voltage of 3.3V for 80% your target amperage.
That said, depending on how long your led strips are, you may need to adjust your power supply. Make sure the fully on White (All 3 channels) current is under the supply's max amperage by 10~20%.
And as Bruce has expertly mentioned, a breadboard is a poor conductor at high currents. Use properly sized cables. Probably 18 AWG at 5 amps.
Passerby
  • 72,580
  • 90
  • 202
  • How do I adjust a PC power supply? Re-using the PC's P/S is economic and ecologic since most P/S outlive the useful life of a PC. I'll definitely replace the MOSFETs. I also learned a bit more drawing from you, thanks! – Yuv Jun 25 '16 at 06:25
  • @yuv the biggest issue with a ATX supply is that it normally needs a decent load on the 5V rail to be stable at 5V and 12V. A decent power resistor on the 5V rail is needed, that's all. Once that's done, the 12V rail will be stable from 0 amps to near it's max 20+. Just use the right size cables to reduce voltage drop. Undersized cables, or like the breadboard rail, are too high resistance for high current loads – Passerby Jun 25 '16 at 06:30
    A better alternative for mosfet irfz44n is IRLZ44N, which is logic level MOSFET. Hope this adds to your help. – Rajendra Jun 27 '17 at 02:52
PC power supplies are not usually good at regulating their auxiliary voltages. Measure the 12V at the PSU with no load, then with 1 and 2 LED strips connected. If you see the voltage drop significantly when a bigger load is applied then that is part of your problem. Regulation can often be improved by drawing 1~2A from the +5V or +3.3V output.
If you are measuring power 'at the wall' with an AC Wattmeter, be aware that the powers supply's consumption will be higher than the power it delivers to the load, and the relationship won't be exactly linear. For better accuracy you should measure the DC Volts and Amps coming out of the PSU.
Getting warm to the point of being 'still touchable' when on a heatsink suggests that the MOSFETs are not turning on fully. Your LED strip is drawing less than 5A. The IRFZ44 has a typical Rdson of 0.02Ω when properly driven, which should only create about 0.5W of heat. But that is with 10V Gate drive. The Pi only puts out 3.3V which is barely enough to turn the FET on at all, so its resistance will be much higher.
To solve the Gate drive problem you need a driver that converts the 3.3V signal to 10V or higher.
Yes! Never trust a breadboard at high current (even 1A is too much for some of them).
To find out exactly where you are losing power, measure the voltage across each component in the LED circuit - including wires, connectors (breadboard), and FET. Start at one end (eg. PSU +) and work your way around the circuit until you get back to it, recording each voltage as you go. All these voltages should add up to zero, ie. the sum of all component voltage drops should equal the power supply voltage. This will tell you which areas need attention.
Bruce Abbott
  • 55,540
  • 47
  • 89
  • Nice catch about the breadboard. I ignored that focusing on the under driven FET. – Passerby Jun 25 '16 at 05:11
  • I'm surprised it isn't getting melty... – Daniel Jun 25 '16 at 05:36
  • How do I draw 1~2A from the +5V or +3.3V output? Yes, my measurements are all with an AC Wattmeter. I am limited in both equipment and budget. While this answer is very helpful and detailed in term of process, it presume a level of expertise that I lack, hence I accepted @Passerby's answer. – Yuv Jun 25 '16 at 06:32
  • 2A * 5V = 10 Watts. 5V / 2A = 2.5 ohms. So a 2.5 ohm 10 watt power resistor. Likely ceramic. You'd want to mount it against the PSU metal and or across a fan. – Passerby Jun 25 '16 at 07:00
  • @Yuv A cheap digital multimeter is all you need. Learn basic electronics here:- http://www.electronics-tutorials.ws/dccircuits/dcp_1.html – Bruce Abbott Jun 25 '16 at 07:13
  • Non-engineer perspective: "draw" = take. But where do I put it? I imagined something like taking those 1~2A and adding them to the lights. Now I understand that it is only "draw" and *dissipate*. If I have already to waste 10W, am I not better off adding a small 10W/5V always-on LED light in the cabinet? something like https://www.amazon.com/Qooltek-Portable-Reading-Eye-care-Orchestra/dp/B00XC2XCNU ? – Yuv Jun 25 '16 at 15:11
  • Yea, that should work too. – Passerby Jun 25 '16 at 18:55
  • Instead of burning 2-3W of power just to keep the ATX PSU stable, I recommend that you buy a SMPS that was designed for 12V LED strips. It will be more efficient. It will also be quiet (these supplies are usually fanless below 400W). – nagylzs Mar 04 '19 at 20:06
