I was wondering what kind of damage a 350V, 6000uF (link to capacitor) electrolytic capacitor could do. will this kill me if it blew up next to me? I have never blown capacitors before, but I definitely would not want to blow this one. Has anyone reading this blown a capacitor this large before? If so, what could I expect to happen, and how could I take precaution against it?
20(1) EE.SE isn't Twitter. No need to use URL shorteners. (2) Please don't use eBay auctions as reference. The auction will expire in a matter of months, the link will perish, the question will loose the context. Instead, post model number and manufacturer. Better yet, post a more permanent link to the datasheet on the manufacturer's site. – Nick Alexeev Jun 24 '16 at 21:56
If properly abused, that capacitor would make quite a bang and mess. It is unlikely that the bang would kill you even if you were a couple of feet away, but you can't rely on that, and it could certainly hurt you pretty severly. A serious injury like loosing one or both eyes isn't far fetched at all.
The secondary effect could be quite serious too. The whole room will be filled with stuff you really shouldn't breath. It could immediately damage your lungs, possibly killing you from oxygen starvation before any medical help could reach you. Even if you can still breath, you may end up at a greatly elevated risk of cancer.
Depending on what is nearby, there may be additional dangers. Anything flammable could get ignited, which comes with its own dangers and likelyhood of property loss.
Deliberately exploding it for fun or to see what happens is irresponsible and a waste of resource. But if you do that for whatever reason, do it in a open field with you at least 20 meters and upwind.
- 310,974
- 36
- 428
- 915
Large capacitors are less spectacular than small ones, because they always have some kind of vent. Often these days, it's in the form of scores in the aluminum can which weaken it so it will fail in a fairly predictable fashion in case of internal overpressure. Top vent:
Typical manufacturer's caution on vent clearance:
Another caution note here
Old-school computer capacitor with bottom vent (the grey rubber circle)
Dangerously hot chemicals can be ejected, as well as bits of aluminum, particularly if stupidly high power dissipation is involved. You should not deliberately induce such failures, and getting too close to any kind of unhoused power electronics should involve at least eye protection and perhaps a full face shield where higher power is involved. The chemicals are not particularly toxic, but they won't do you any good if inhaled.
- 376,485
- 21
- 320
- 842
There are too many factors to consider to say "yes it will kill you" or "no it will not kill you". It might just pop a seam and vent smoke for a while, or the entire thing might explode violently, showering the entire room with boiling electrolyte and send shrapnel everywhere.
Your best bet at prevention is to just not be stupid. Don't over-volt it and don't connect it backwards. If you're still concerned about it exploding, set up a blast shield between you and the capacitor (but don't enclose it! That could act like a secondary bomb!)
If you keep it within its specified operating conditions, it won't explode. Just be smart and be safe.
- 21,042
- 8
- 61
- 95
In my experience large electrolytic capacitors all have pressure vents built into them, especially those with screw terminal connections. An overload or reverse voltage will cause the capacitor to heat up until the vent (usually hard rubber) pops and vents out smelly gases, maybe leaving a puddle of electrolyte by the vent. At this point the capacitor is already destroyed and not usable.
The capacitors that go "BANG" and send their metal cans flying along with a cloud of stinky wax paper are the smaller 'can' type electrolytics found on pc boards. I have seen tantalum capacitors go "POP" but with much less violence-though they are prone to catching fire and burning the PCB. Disc capacitors tend to crack open if overloaded-the polarity does not matter. Unless you overvoltage them or reverse voltage them or have a high current ripple in the DC power line beyond the capacitors rating they are safe to use.
I have had them (electrolytic can capacitors) explode in my face due to being installed in reverse. When building circuits pay attention to DerStom8's answer and do not install one in reverse!
2On the contrary, for tantalum capacitors (particularly leaded, epoxy-dipped ones), over voltage or reverse voltage under high-current conditions can result in a literal firework. – user2943160 Jun 25 '16 at 02:02
@user2943160. I have seen tantalums "POP" and leave nothing but 2 thin wires where the capacitor used to be. The use of the term 'less violence' is relative, by all means. But I think you also are including burning of the PCB due to it getting coated with soot from the capacitor, making the PCB conductive and actually burning. I used to test PCB mounted fuses this way at 100 amps of fault current. I do miss those fun days... – Jun 25 '16 at 04:09
1@user2943160 is right: tantalums can literally catch fire. See [this answer](http://electronics.stackexchange.com/a/99321/29434) by Russel McMahon. – LorenzoDonati4Ukraine-OnStrike Jun 25 '16 at 09:09
I have seen wet tantalums that have gone spectacularly pyrotechnic that have *vapourised* the nickel lead; considering that nickel *melts* at 1455C, I think that speaks for itself. – Peter Smith Jun 25 '16 at 13:47
Exploding this capacitor deliberately will not be so exciting. As other answers describe, the precut vents will open up to release the pressure harmlessly.
But you can make it spectacular if you charge it with 350V DC (in the correct polarity of course) and short out its terminals with an iron screw driver. The full energy can be held by this capacitor is 367 Joules and this is pretty nasty. If you short the terminals in a fraction of a second, hundreds of ampere will flow causing metal melt down with huge pop and spectacular arcing....
That will be far dangerous than exploding the capacitor itself. Having said all these, I don't recommend you to try this out unless you know the dangers associated with it.
- 1,695
- 1
- 11
- 16
1Precut vents can open "rather rapidly". I have been "shot" with a capacitor's innards (long ago) and have heard similar tales from other people. Not as spectacular as your screwdriver "suggestion" though :-). – Russell McMahon Jun 25 '16 at 17:20
Really? I got to try that out. Must use very low source impedance high voltage such as mains voltage and supply it into one cap behind a protective shield. This won't give enough time for the vent to do its job and hopefully the whole body pops. – soosai steven Jun 25 '16 at 22:21
1I've never heard of a can exploding - and I've been playing in this area for 50 years+ [!] BUT that's not to say it doesn't happen. I have heard of numerous end ejections though. Failure mode of a cylinder of equal strength material throughout is a longitudinal wall split due to "hoop stress" exceeding end stress by 2:1. If the slits weaken the top by a factor of 2 or more you can expect quite reliable end ejection failures. | If it's 'fun' you are after, easier are PET plastic bottle (Coke etc) pressurised to 150-200 + psi. **LOUD**. Don't try this at home NSFW IANAL YMMV. – Russell McMahon Jun 26 '16 at 01:34
Not long enough :-). Mind can't work out why body seems to be starting to not keep up with its commands. Some of it feels like "just a few years ago". Some doesn't. – Russell McMahon Jun 26 '16 at 02:45
I bought my 1st transistor somewhat over 50 years ago. (OC71 I think). ICs existed but were so unusual as to not be seen in any everyday equipment. Learning how not to kill yourself along the way is useful. Especially if you like making things explode :-). Pop bottles not too too bad compared to most else BUT you could probably die very unlucky worst case. I've had 1200 VDC shock, several N00V smaller shocks and numerous 230 VAC mains shocks. I try very hard indeed to avoid these as life goes on, in order that it may. [Along the way](http://bit.ly/RedolentRedundancies) – Russell McMahon Jun 26 '16 at 02:45
Based solely on a video of a 1 Farad, which is 200 times greater capacity than a 0.006 farad capacitor you link, it's unlikely to do anything other than take your eye out or leave a welt. It's not big enough to spew much liquid electrolytic, and not big enough to fill a room or even a small cabinet with smoke. It may just vent instead of explode. Think of a small firecracker.
A 6 milli farad cap is pretty small. It will however stink the room up something fierce.
Unless you are holding it in your fist or something when it explodes. That could take a finger off.
- 72,580
- 7
- 90
- 202
his capacitor has an energy capacity slightly greater than that 25V 1F capacitor. – Jasen Слава Україні Jun 25 '16 at 04:59
@jasen possibly. Only if charged at over 350V, instead of reverse voltage at much less. It's still limited by the volume of its electrolytic content and Physical mass. The trade offs pretty much make the two even imho. – Passerby Jun 25 '16 at 05:05
physically it's about the same size, it's likely to make the same sized pop too, – Jasen Слава Україні Jun 25 '16 at 05:09
With a 3-phase Variac supplying voltage through a rectifier with nothing limiting the charging current, I once blew up several 350 V, 2500 uF capacitors by turning up the voltage too quickly. At least one capacitor blew out the top and the Variac was damaged. The rectifiers and capacitors were inside a perforated metal enclosure. That was about 45 years ago and it taught me some lessons that I still remember.
Over the years, I occasionally heard reports from people I worked with describing similar capacitor explosions due to various types of faults. We never used capacitors like that without some kind of protective enclosure.
Small capacitors without precut vents are the dangerous ones. I had the can of one dent it's self on the ceiling at work. Germanium low power transistors in a metal TO1 can are even more dangerous. They have heatsink compound inside that can vaporize & blow the can off like a bullet. In a chart recorder pre-amp I repaired, where an insulation breakdown had applied mains voltage across it, it had dented the aluminium lid, while the bottom came down so hard, the edge sheared through one of the steel wire leads & cracked the PC board. If you are likely to blow one of them up, WEAR SAFETY GLASSES!, & a face mask if it's a germanium transistor.
- 381
- 1
- 7
Likely to KILL you? Not unless you put your head right next to it or something. Likely to spatter you with hot gunk from its internals? Oh HELL yes! It’s unlikely to do more than scare you senseless, and give you some nifty burns.... like what you get from accidentally dropping molten solder on yourself while soldering. Hurts like hell but won’t kill you. Of course if any of those acidic chemicals or the safety plug hit you in the EYE, it’ll be a whole different story. Seriously, if you must blow up that capacitor, treat it like a big ass firework, stay at least 30 feet away, and do it outside. Source: I’ve worked as an electrician for over ten years.
- 11
- 1
Stored energy = 0.5CV^2 =~ 367 Joule.
That's a serious amount of energy - slightly below
the muzzle energy of a '38 special'.
IF you directed all that energy unidirectionally and drove something solid with it then it could kill.
IF you could couple all that energy into a 6mm steel ball bearing it would have an exit velocity of about 1 kilometre/second [!!!].
BUT in almost all cases worst case is being shot in the face with an energetic wad of caustic goo. Losing an eye could happen, but more likely is just having a story to tell to your friends.
(Ask me how I know :-) - but not THAT energetic).
So, as has been noted in various ways by various people.
Check polarity
Be aware if you stand above it that you are facing a loaded gooey-shelled 38 special equivalent.
Do not place such a capacitor in an enclosure such that the energy could be focused and channelled.
- 147,325
- 18
- 210
- 386
I have been evaluating some ultracapacitors (the only ones that are good to 85C to my knowledge): http://www.ioxus.com/files/5014/5200/4340/Ioxus_DataSheet_Titan_60mm_151217.pdf When fully charged, there is *4556.25* Joules of energy per device. I have yet to test to destruction (which I need to do) and when that is due, I will sell tickets. – Peter Smith Jun 25 '16 at 16:42
@PeterSmith Right up there with all but the top hunting rifles. That would power a genuine rail gun quite nicely, probably :-) – Russell McMahon Jun 25 '16 at 17:17
I have 10; that equates to roughly 50% of the energy of a hand grenade :) – Peter Smith Jun 25 '16 at 17:23
