I'm trying to write a loop for two binary values that repeat periodically at a specific amount of time that goes indefinitely or until a certain condition is met.
Here is what I have wrote (below), but the error states that I should be using the 'wait' statement with 'until' but when I use that then it says that the Boolean expression is used incorrectly.
This leads me to believe I'm using the loop wrong or doing something else wrong that I can't figure out.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity moove is
port (clk : in std_logic;
rst : in std_logic;
count : out unsigned (7 downto 0));
end entity;
architecture moving of moove is
constant period : time := 19.5 ms;
constant cycles : integer := 120000;
begin
forwrd: process (clk)
begin
if rising_edge(clk) then
if rst = '1' then
count <= "00000000";
elsif rst = '0' then
for i in 1 to cycles loop
count <= "01100100";
wait for period;
count <= "10010110";
wait for period;
end loop;
end if;
end if;
end process;
end architecture;
