I am working on a university project in which I need to interface a PIC18F4550 with an I²C EEPROM.
I read many codes and saw many projects on this topic. And I wrote a sample code from MPLAB C18 (and I tried many codes also), but no one worked with me.
I don't know where the problem is. Everything is OK with my code and with my circuit, but the SCK signal did not generate the CLK signal for writing and nothing has been written to EEPROM.
Here is the code:
#include "p18f4550.h"
#include "i2c.h"
#pragma config FOSC = HS
#pragma config PWRT = OFF
#pragma config BOR = OFF
#pragma config MCLRE = ON
#pragma config PBADEN = OFF
#pragma config ICPRT = OFF
#pragma config LVP = OFF
#pragma config WDT = OFF,DEBUG=OFF
unsigned char arraywr[] = {1,2,3,4,5,6,7,8,0};
unsigned char arrayrd[20];
void main(void)
OpenI2C(MASTER, SLEW_ON);// Initialize I²C module
SSPADD = 10; //400 kHz Baud clock(10) @20 MHz
while(1)
EEByteWrite(0xA0, 0x30, 0xA5);
EEAckPolling(0xA0);
EECurrentAddRead(0xA0);
EEPageWrite(0xA0, 0x70, arraywr);
EEAckPolling(0xA0);
EESequentialRead(0xA0, 0x70, arrayrd, 20);
EERandomRead(0xA0,0x30);
This is the code of OpenI2C:
/* $Id: i2c_open.c,v 1.1 2004/10/06 23:16:42 curtiss Exp $ */
#include <p18cxxx.h>
#include <i2c.h>
* Function Name: OpenI2C *
* Return Value: void *
* Parameters: SSP peripheral setup bytes *
* Description: This function sets up the SSP module on a *
* PIC18CXXX device for use with a Microchip I²C *
* EEPROM device or I²C bus device. *
void OpenI2C( unsigned char sync_mode, unsigned char slew )
SSPSTAT &= 0x3F; // Power on state
SSPCON1 = 0x00; // Power on state
SSPCON2 = 0x00; // Power on state
SSPCON1 |= sync_mode; // Select serial mode
SSPSTAT |= slew; // Slew rate on/off
#if defined(__18F2455) || defined(__18F2550) || \
defined(__18F4455) || defined(__18F4550)
DDRBbits.RB1 = 1; // Set SCL (PORTB,1) pin to input
DDRBbits.RB0 = 1; // Set SDA (PORTB,0) pin to input
#else
DDRCbits.RC3 = 1; // Set SCL (PORTC,3) pin to input
DDRCbits.RC4 = 1; // Set SDA (PORTC,4) pin to input
#endif
SSPCON1 |= SSPENB; // Enable synchronous serial port
