I am xilinx ISE and virtex 5 engineer.
I found Vivado something when I ran across the internet. What is the difference between ISE and Vivado?
Should I have to move to Vivado from ISE?
Vivado is Xilinx's next-generation replacement for ISE. It was released in 2012, and since 2013 there have been no new versions of ISE. You have to use Vivado if you're working with the 7-series FPGAs* or newer. However, Vivado cannot target older FPGAs including the Virtex 5, so you're stuck with ISE for those.
* (with some limited exceptions - ISE can target some Zynq and Artix devices, but it's not recommended)
