I was planning to simulate a circuit which will control a single phase induction motor in LTspice where mains is 230VAC 50Hz. In my previous question, I failed to find an example: Modelling a "single-phase permanent split-capacitor motor" in LTspice
I was looking for any single phase induction motor circuit at any torque just for simulation purposes. I could only find the following eq. circuit together with resistances and reactances:
Here is the link for this realistic circuit: http://www.globalspec.com/reference/63637/203279/section-6-single-phase-motors
I adjusted this circuit to use in LTspice simulation. I guess all the reactances (X) in the above circuit are inductive; so to use in LTspice I need inductances.
Therefore since inductive X = 2 * pi* f *L; in my case I took L = X / (2 * 3.14 * 50). I took the slips as 0.005.
Here is after modification for LTspice :
My questions are:
1-) Is my modification reasonable and does it makes sense to use this in LTspice as a motor?
2-) There are two slips, I took both 0.005, for a fan motor is that reasonable in steady state?
note: I think a good motor simulation requires a lot of effort, but my aim is to represent the motor in LTspice in a very simple way.
link: http://eesiiest.weebly.com/uploads/2/6/9/2/26921317/478_eeselectric_machinery_6e.fitzgerald.pdf
