The problem "power supply vs powered device" can be simplified this way:
The Rated voltage is the problem for the device, the device must be able to withstand voltage, so power supply must not exceed it. If exceeded, device can fail (manufacturer do not guaranties correct working). Also the power supply voltage should not go below minimum rated voltage. This usually do not fry the device, but manufacturer do not guaranties correct working of the device on lower voltages.
The Rated current is the problem for the power supply. If the current load of power supply is exceeded, power supply can fail. The device drains current from power supply, so power supply must be able to provide that much current. Power supply should have at least current rating the same as of the device. If the ratings are the same power supply will operate at 100% load. So it is better to have higher current rated power supply so it can operate on lower load (to have longer life).
In your case, answer is NO, you do not need resistor.
