88
For a very long time I have been wondering, where does electricity go after being used? When I use my tablet it runs from a battery. Where does the power go?
Olin Lathrop
  • 310,974
  • 428
  • 915
Ethan T.
  • 869
12 Answers12
130
"Electricity" is not a thing, more like a concept. "Amount of electricity" does not have a real meaning. You can have some specified amount of power, voltage, current, or other measurable properties, but not "electricity". For those that don't fully understand current, voltage, and power, it is best to just avoid using the word "electricity" at all, since they'll most likely use it incorrectly.
To therefore answer your question, electricity doesn't "go" anywhere since it's not a thing or stuff that ever was anywhere in the first place. Current and voltage together can be used to move energy around. When a battery is powering your tablet, it is producing voltage and current, thereby transferring power from inside it to the outside. The tablet uses that power to operate the computer inside, light the screen, transmit data over radio waves, etc.
Energy (and power, power is just energy per time) is not created or destroyed, just moved around. In the case of the battery powering the tablet, the energy starts out in chemical form inside the battery. It then takes on electrical form coming out of the battery. The tablet uses it in electrical form, but eventually it gets turned to heat. If you leave a tablet running just sitting there, you should be able to notice that it's a bit warmer than whatever it's sitting on. The energy that was in the battery in chemical form is now in the stuff the tablet is made of in thermal form. Eventually that will heat the air in the room, which will heat something else, etc. By the time the relatively small amount of energy in a tablet battery is spread out over a whole room, you'd need sensitive scientific instruments to detect it.
Chad Branzdon
Olin Lathrop
  • 310,974
  • 428
  • 915
  • 73
    I don't read this as disrepectful of the OP. It's more like sharing a laugh with the OP about how mixed up the initial question was. This kind of thing often happens to some degree when you have a question you don't understand well enough to google the answer for yourself (i.e. the only kind worth bothering other people with). **Asking a silly question doesn't make you a bad person**, and it should be possible for people trying to answer to say the question is nonsense without making anyone feel bad, IMO. I loved the opening paragraphs; that was a fun start. – Peter Cordes May 13 '16 at 10:44
    *Off topic comments removed.* This is not the place to discuss what you feel "electricity" means. – W5VO May 16 '16 at 17:29
  • The Energy is released to the surrounding atmosphere...This is what causes Global Warming ,in the long run. – b.sahu Nov 09 '16 at 17:02
    @b.sahu, no, global warming is because of a feedback mechanism which traps the Sun's heat, if it was just the heat we were dissipating we wouldn't have a problem at all. – crobar Sep 13 '18 at 13:09
67
An electrical circuit is like a bicycle chain. It must have a complete circuit to flow. A bicycle chain stops turning when the rider stops injecting energy into the system (when they stop pedaling.)
And the flow of electricity in your tablet (or whatever) stops when the battery stops injecting energy into the system. Because you have depleted the chemical process that produced the electricity. You can replace the depleted battery with a new one that still holds the chemical potential, or you can re-charge the battery and reverse the chemical process.
Richard Crowley
  • 14,382
  • 39
    I like the bicycle chain analogy. That answers the question "Where does bicycle chain go after being used?" – Transistor May 13 '16 at 06:33
    How does RF work then? It doesnt need a complete circuit – Vajura May 13 '16 at 10:57
    @Vajura: The "complete circuit" is actually a (very, very convenient) simplification of the whole system. The short of it is that the electrons are moving back and forth quickly enough that they don't need to ever leave the antenna. – Ignacio Vazquez-Abrams May 13 '16 at 11:13
    @Vajura if a bicycle is “DC powered” with its chain, a steam locomotive is AC powered through the piston rods, and a [toothbrush bug robot](https://www.youtube.com/watch?v=Dr9zi5tSsi4) is RF powered. – leftaroundabout May 13 '16 at 11:43
    The DC bicycle chain is actually driven by 2-phase alternating legs. That makes the pedals, cranks and chain wheel into a sort of rectifier. The ratio between the front and rear sprockets determines the transformer ratio. – Transistor May 13 '16 at 20:08
  • Beautiful answer. By the way, Whatever DC or AC... the situation remains the same. from the energy-source, whether we flow the chain in 1 direction (like D.C.) or moving the chain to-and-fro (like AC), we pay for the "creation of current", or "inserting the energy in form of the current". Not for electrons or electric charged particles. – Always Confused Jun 01 '16 at 04:10
  • Actually, more like a smooth belt than a bicycle chain. Only one side of a bicycle chain actually matters; if you had an infinite spool of chain you could feed it into the tensioned side of the system leaving the return side open and it would work. Wheras something like a smooth belt won't work unless the other side is there to maintain belt tension. – Chris Stratton Jun 07 '18 at 19:45
22
A layman's answer: it doesn't "go" anywhere. It gets turned into heat, light, sound waves, and radio waves, and some of it is used up to change the state of the flash memory inside your tablet. Most of the time, heat makes up by far the largest part, because of inefficiencies. When you actively use wifi or GSM (using your device as a cell phone), a lot of energy is used to produce the radio waves. You can notice how much faster your battery is depleted while you are connected to a wifi or mobile network.
To be a little bit more pedant, it's not "electricity", but "electrical energy".
vsz
  • 2,554
  • 32
  • You have forgotten infrared radiation (as main consequence of heat). – Egor Skriptunoff May 14 '16 at 14:46
  • It turning into heat, light, sound etc. could be termed as "going" somewhere, right? I believe that's what the OP would have meant. – Julia May 14 '16 at 18:50
  • Maybe so @anon .. then the answer to OP is that electricity just *goes* into the atmosphere (as a different form energy: heat, light, etc.) – Paulb May 16 '16 at 19:33
17
The concept of electricity we use is a simplification. It's not wrong per se, but it's far more complicated than the concepts we assume.
Here's a great resource I found, which explains in detail what electricity is and how it works. It's written by William J. Beaty, who's an electrical engineer:
amasci.com/elect/elefaq.html
Here's an excerpt from the site, relevant to this question:
Why does the electric company bill us, since it takes back all of the electrons it gives us?
The electric company does NOT sell electrons. Instead, it only pumps electrons. It pumps the movable electrons which fill the wires. The electrons are provided by the atoms of the copper. You pay for a pumping service!
Also, since power lines use AC, the electrons really don't move much at all. Instead they sit in one place inside the wires and vibrate back and forth. (It's somewhat like sound: the sound waves move fast, but the air molecules just vibrate back and forth without flowing forwards.)
TravisEz13
  • 103
cst1992
  • 273
    I like to joke that the reason the mains use AC is that if they used DC, the electric company would have to keep supplying fresh electrons, whereas using AC means that they get to keep charging for the same electrons over and over again. – supercat May 14 '16 at 16:29
  • So the city charges me for water, and they charge me to take it back again (sewer)! Not fair! They should only charge once. It is not like I can put more in the sewer than I take from the water pipe anyway. –  May 16 '16 at 01:52
    @no comprende, oh yes you do: you drink water at work, then go home and deposit it in the sewer! ;) – Jester May 16 '16 at 17:20
  • I just realized that musicians keep selling the same sound over and over. So, if it is not light, radio or gravity, you are being ripped off! –  May 16 '16 at 21:32
The electrons themselves drift from the negative terminal of the battery, through whatever current path they happen to be on, and then eventually back to the positive terminal.
The power that they transfer gets dissipated as heat (wasted), light (e.g. display), kinetic energy (e.g. speaker), and so forth.
Tom Carpenter
  • 63,168
  • 139
  • 196
  • Then the negative charges flow through the battery electrolyte, in order to obey the "complete circuit" rule. ...only sometimes they're protons instead, as with lead-acid batteries! Alkaline batteries have -OH ions going between the plates to complete the circuit. In any case, the battery is not the source of the "electricity," instead it's just a pump, and the flow is a closed circle with no source or sink. – wbeaty Dec 18 '16 at 03:00
Electricity doesn't get used, instead energy is transferred using electrons. It is the energy that you are using. If we imagine a world without electricity, we can come up with a similar setup to how electricity is used but with something we are more familiar with.
Imagine if you had a special water line coming into your house with a return line back to the water company. The whole system was closed off and pumped water in circles. However, you could tap into this circle by putting a plug in it. Once you plugged up the line, one side of the plug would have pressure from incoming water and the other side would have no pressure. If, for example, you had a blender you wanted to use, your blender would have two tubes. You plug one tube into the high pressure and the other into the return pipe. The water pressure (voltage) pushes against a valve in your blender. When you change how open the valve is (resistance) the water starts flowing into your blender, pushes some sort of water wheel, and goes out the return pipe back to the water company. The water company is making sure that it keeps the pressure coming but bills you for the water flow. The water would not be getting "used up". They could even make the water direction alternate back and forth instead of having to push in a full circle.
For a battery you could have pressurized water in a cylinder that was divided in half. You'd pressurize one half and then the water would flow to the other half. Eventually you'd use up all the water in the pressurized half and need to recharge or push the water back into the pressurized half.
codeMethod
  • 51
Electricity is one way to do work. To better understand it let's talk about another way to do work.
As a waterwheel in a river turns, the machinery attached to it inside the wheelhouse is used to do work. In this scenario, the water is analogous to the electrons moving through wire/devices. Neither the water nor the electrons disappear, they just go from a higher energy state to a lower energy state, and that difference in energy is used to do work.
More energy is needed to put the water/electrons back to a higher energy state.
Terry
  • Yes, there was work involved in getting the electricity, unless it is wind or solar or other passive devices, if you want to consider them passive. The work being a turbine generator or coal fired plant or even nuclear. the spent energy is spent as work, of some kind, even if it's an LED light or LED TV. And heat is usually evidence of the work. – Tim Spriggs May 17 '16 at 19:15
Take analogy with Water flow
Take an analogy with water-flow . ( Current=>Flow of something)
If you stop the hand-pump, water would not flow, and energy transfer in form of water-flow would stop.
But the water would still remain there.
Likewise, Electric-current is the flow of charge.
If we break the circuit, current of the charged-particle, will be stop;
but the charged particles (and they're chemical component of the matters) would still remain there.
They would just stop there overall(net)-movement.
They would also not be able to carry the energy.
When the battery finishes; all the reactants in the battery get converted into product as much as possible (the remaining reactants, if any, no-more could be obtained in equivalent amount) . so it can no-more continue pump electrons.
When battery finishes, The electrons remain within the constituent-material of circuitry.
While battery works and gradually finishes, the energy (that was stored in battery), gets out to environment The energy (=unstability; or ability to do work) that was stored in new-battery, comes out (when the electrical current do some work in the gadget). The energy, gradually lost in the surroundings when the gadget works. Say, for your tablet-computer, the energy lost as the lights coming-out from display, the sound from speakers, the heat from electric-paths, etc.
Always Confused
  • 1,591
  • 49
The other questions talk about flow of electrons, not really answering the specific question. In the case of a battery powered tablet, it starts with chemical energy stored in the battery. As the device is active, this chemical energy is released to move electrons round the various circuits. Some is converted to photons, and released as light from the screen (not a lot, maybe a few %). Almost all of the energy is converted to heat. Everything the processor does produces just heat, the computational work does not store energy. A more efficient processor can do more computation for the same amount of heat generated. You often won't notice this heat being generated by battery powered devices because the rate of heat generation is low, and the temperature gain is often small.
Sean Houlihane
  • 3,733
Although your main question says "electricity," your correct it by rewording your question as "Where does the power go?" The answer is simply, it mostly gets converted to heat. Even the portion that gets converted to sound, photons, and radiation, are considered a "form of heat" (they "warm up" some portion of the universe).
Guill
  • 2,430
I like this question because it shows so many differing points of view - here is mine.
The electricity (in this case, energy from @EthanT's tablet battery) is hard to define as a general term because it has so many forms from its inception; it was mined or captured, and converted, transmitted, converted again chemically in the battery, then performed the work in the tablet. At each step along this path there are losses as everything goes to a higher level of entropy. When all is done, the matter and energy are all still present somewhere, but they are in a more random state, making them less useful to perform specific work. So nothing is lost, it is just progressively more disordered until it is as random as it can get.
Sort of like my desk.
One point of view anyway.
John Birckhead
  • 10,524
It does not go anywhere, since it is just a medium of transmission. What the power companies are charging you for is not electricity, but energy. Electricity (more specifically, the movable charge carriers in conductors) is just the way of transmitting the energy to you.
Chad Branzdon
