Power-on sequencing I understand. But why do power-off sequencing? I could understand if you had to do something before power died, or maybe you just wanted to shutdown I/O before core so that no crazy pins are toggled while you're on your way down.
Is there a situation where you could risk damaging the part? Only thing I think of there is maybe ESD diodes.
SamGibson
  • 17,231
  • 58
confused
  • 1,786
The same problems as during power on apply to powering off.
A common problem is that in ICs, transistors are placed so that their junctions are reverse biased by the supply rails. If a higher voltage supply turns on slower or shuts of faster than a lower voltage one, that assumption may no longer be true, large currents can flow through the (now) forward biased junctions, destroying them.
Simon Richter
  • 12,031
  • 49
