I have laptop batteries that are a few years old and lost their charges, but which I've still kept "just in case"*. However, I've heard that letting them lose all of their charges can be dangerous. Does this mean they could burst into flames one day?
How much longer can I keep them around?
*Note: Yes, I do realize they probably won't hold charge anymore, but that's not my quesiton. I'm only asking about their safety, not usefulness.
user541686
  • 1,154
    Try reading http://electronics.stackexchange.com/questions/230155/why-is-there-so-much-fear-surrounding-lipo-batteries, in short: I would recycle them. – PlasmaHH May 03 '16 at 08:21
  • @PlasmaHH: http://electronics.stackexchange.com/questions/230155/why-is-there-so-much-fear-surrounding-lipo-batteries#comment499679_230164 – user541686 May 03 '16 at 08:23
  • I agree with PlasmaHH, although it is safe to store these batteries there is not much reason to do so. All charge will slowly leak away and that accelerates the deterioration of the cells. If a battery cannot hold much charge anymore, recycle them. – Bimpelrekkie May 03 '16 at 08:27
  • @FakeMoustache: A couple of things: (1) In order to tell if it can hold a charge I have to actually try that, right? Doesn't the answer on that page suggest that to be dangerous? (2) If it *can* hold a charge (which I actually suspect it will be able to... or at least it was when I tried it a year or two ago) then we're back to the original question: how long can I keep them around? The answers on that page don't actually answer my question, hence why I asked a separate one (also click the link in my previous comment). – user541686 May 03 '16 at 08:35
  • Yes to know if a battery can still hold a charge, you will have to try it. **But** when you charge it and use it immediately it might work but if you charge it and try using it a week later it might have lost (most of) the charge. I would consider that an unusable battery and recycle it. There is only a danger when **charging** a cell in an **uncontrolled way**. If you charge the battery the way it is intended to be charged, it will be safe. Storing a battery should never be an issue even when it's worn-out. – Bimpelrekkie May 03 '16 at 08:54
  • But I think you concern yourself too much with this. Just recycle the battery when it is worn-out. Lithium based batteries also deteriorate (age) when you're not using them. There is no point in storing worn-out batteries. There is a point in recycling them as their chemicals can be re-used. – Bimpelrekkie May 03 '16 at 08:55
  • I've never heard of a Lithium battery bursting into flames because it was too flat, unless it's got some wacky electrolyte that form dendrites when flat (unlikely) I think it's pretty safe to leave them in the cupboard (their self discharge is measured in % per year), but as everyone's been saying, if you don't need them for anything, chuck 'em – Sam May 03 '16 at 09:45
Yes, laptop batteries are rigorously designed to be safe under all normal usage conditions, including long-term storage. If they are stored too long then they will self-discharge to voltages so low that the may no longer be safe to recharge. If this occurs the BMS (Battery Management System) will not allow any further use of the battery, and the OS will report that the battery needs to be replaced.
When Li-ion cells are at low voltages (typically < 1.5V) the copper current collector can dissolve. If the cell is later recharged to higher voltage then the copper will plate back out - but not necessarily in the same uniform way. In particular it may plate into sharp dendrites that could pierce the separator and lead to internal shorts and venting (possibly with flames). Note that this dangerous scenario can occur only if the battery is subsequently recharged (which is prevented by the BMS). In particular, it does not occur when the battery is self-discharging in long-term storage.
While there have been improvements such as ceramic separators to help control internal shorts, they cannot be completely prevented, so a well-designed BMS will always permanently disable the battery if it detects such dangerous conditions.
However, for healthy batteries it usually takes a very long time for the cells to self-discharge to such low voltages (assuming they are stored at reasonable initial capacity, usually 40-60%). It is not unusual to hear of NOS (new old-stock) batteries over 5 years old that still work well. Occasionally one even hears of 10 year-old NOS batteries that still function (see e.g. many reports on Candlepowerforums or BudgetLightForum where users "harvest" 18650 cells from laptop packs for flashlights or DIY projects - where now we have the risky case where the user (vs. BMS) is responsible for deciding when the cell has discharged too low to be safe to recharge).
Bill Dubuque
  • 1,201
