The text that is above the figure is from my textbook and i am having difficulty to understand what it is trying to say because it's not in detail!! why only remove high frequency and prevent low frequency using capacitor on ground G2? also What is the difference between both the grounds?
Hilton Khadka
  • 811
  • Love the use of **condensator**. A low frequency ground (or earth) loop can cause oscillation (aka motor boating - see https://en.wikipedia.org/wiki/Motorboating_%28electronics%29) – JIm Dearden Apr 29 '16 at 13:47
The critical reason for the low frequency blocking capacitor is avoiding large DC currents to flow. In any practical application, "ground" is only at zero potential in a very small region; the "ground" potential can vary across a circuit board, equipment chassis, or or larger assembly of equipment (telecom, AC power, building) due to current flow and non-zero resistance. Thus, connecting the shield of the twisted pair to both the sensor and the amplifier could cause such current flow between G1 and G2, since they are different "grounds." Depending on the reasons for the ground loop and the common grounding conductor, it is possible for a little interference to thousands of amps to flow because the two grounds otherwise have a high-impedance connection. This depends on the equipment and other electromagnetic situation at each end of the sensor wire connection.
The use of a capacitor means that high frequency noise/EMI is conducted away from the sensitive in-amp nodes because the capacitor connects the two grounds only at high frequency (where the capacitor presents a low impedance). This also reduces the buildup of large potential on the shield relative to the amplifier due to this high frequency noise because they are conducted, through the capacitor, to the ground of the amplifier.
Further reading:
user2943160
  • 2,878
  • 32
  • Why do we need to avoid large DC current? – Hilton Khadka Apr 29 '16 at 14:14
  • Possible ways for the DC current to be damaging to the equipment are I^2R heating, where the current heats the conductors and may exceed temperature rating, and electromigration/corrosion, where the high current causes metal ions to leave the ground frame of a device, weakening the metal. – user2943160 Apr 29 '16 at 14:18
  • Opposite of ferrite beads?? – Scott Seidman Apr 29 '16 at 14:21
  • why do we only ground the HF noise and the not the LF as well ? I'm confused!! – Hilton Khadka Apr 29 '16 at 14:36
  • The low frequency noise includes the DC component, which must be blocked as I have discussed. Thus, the only noise that is being conducted to the amplifier ground through the shield is the high frequency noise. Also, keep in mind that HF/LF are relative terms depending on the application. I am uncertain what these frequencies are for the diagram given, but the overall approach should be relevant. Please also consider the Further reading links I gave for additional information. – user2943160 Apr 29 '16 at 14:45
  • Now it is becoming clearer!! The only last question i have is, if we ground the HF in both the places(sender and receiver) wont that create ground loops? I am thank full for the links you gave me!! but i have limited amount of time to spend on this course! – Hilton Khadka Apr 29 '16 at 15:03
  • "Ground loop" usually refers to the low frequency (DC, 50/60Hz) loops. Generally (though not always, see switching power supply noise), the high frequency energy can generate some high voltages, but will not transfer much power. In either case, it is advantageous to conduct that high frequency energy to ground so that it won't interfere with other electronics. – user2943160 Apr 29 '16 at 15:08
Your circuit shows two remote grounds; one at the sending end and one at the receiving end. Those two grounds will not be at the same potential - imagine a bunch of plant machinery at one end and another bunch of plant machinery at the other end. The Plant machinery can create significant ground currents and the relative potential difference between the two ends is just not constant.
However, neither is it going to be hundreds of kHz - it's going to be mainly from 50 Hz to a few hundred Hz and maybe a few kHz. But, if you put a wire between those two points what would happen - you'd get ground currents travelling along the screen of the cable. Those ground currents may be "low" in frequency but they could still induce "volts" in the signal wires. Yes, it'll be common mode noise but it could still upset things and severely degrade the signal at the receiving end.
Worst case scenario - it could damage circuits.
Personally I'd ground the screen at the receiver end and leave it open circuit at the send end and if it doesn't look good I'd put the capacitor at the sending end. Personally I think they got there diagram the wrong way round.
