Since the skin depth of copper at 1Ghz is about 2.3 micrometers, it doesn't seem like aluminum would provide a worse signal to noise ratio.
7075 aluminum is also much more resilient and stronger than pure copper, so it should be able to bend more without breaking.
The main problems seem to be splicing wires (due to oxidation) and Power over Ethernet, but for other uses, aluminum wires seem like a cheaper and lighter (for aerospace) solution.
So why do we still use copper for data?
genealogyxie
  • 233
  • Ironically, it's because we still use copper for everything else. Copper and aluminum don't mix. – Ignacio Vazquez-Abrams Apr 29 '16 at 05:57
  • Are you talking about galvanic corrosion? I don't think galvanic corrosion is a major problem for most electronics – genealogyxie Apr 29 '16 at 06:12
    Help yourself to [CCA Ethernet cable](http://www.ebay.de/itm/like/191110535297?lpid=106&chn=ps&ul_noapp=true) – Dmitry Grigoryev Apr 29 '16 at 06:45
  • I think mainly it's due to economies of scale, a large copper wire manufacturing industry has been developed over many years and it would require massive investment to change it (and yes, I know there are aluminium wires out there, but you don't see them for sale in your local hardware store) – Sam Apr 29 '16 at 07:35
    Gigabit ethernet isn't 1GHz, it's 125MHz (see e.g. [here](http://www.hardwaresecrets.com/how-gigabit-ethernet-works/)). I'm pretty sure that changes the depth of the skin effect (fun fact: contrary to what many people think, gigabit ethernet is certified for 100m over plain cat5, just like fast ethernet). It's also possible the DC resistance of copper vs aluminium plays a role, I remember that at 100m you pretty much need copper (or better) to reach that spec. – marcelm Apr 29 '16 at 14:14
    @Tom No, aluminium (and iron!) is cheaper enough that it is worth it to make network cables of them. If you buy your cables too cheaply, you'll likely get CCA (Copper Clad Aluminium) or CCS (Steel). You'll have a hard time running gigabit over several meters of CCS; CCA seems to fare a bit better but I still remember people complaining about not getting gigabit to work reliably over it (maybe at greater cable lenghts). – marcelm Apr 29 '16 at 14:19
    @marcelm for power applications, particularly AC power transmission (cross-country scale), copper-on-aluminum, copper-on-steel, or (particularly) aluminum-on-steel are better options. For data applications, copper is certainly fine. – user2943160 Apr 29 '16 at 15:30
  • Copper coated aluminum wires are in the market since long ago..... – soosai steven Apr 29 '16 at 17:46
    Power transmission is generally done with aluminum cable with the centermost strands being high tensile strength steel. Using anything else would be foolish - you need steel's physical strength and aluminum is 10 times cheaper a conductor than anything else. https://en.wikipedia.org/wiki/Aluminium-conductor_steel-reinforced_cable – Harper - Reinstate Monica Apr 30 '16 at 02:55
Aluminum oxide is stable, hard (as sapphire, because it IS sapphire, aka alumina, Al2O3), and nonconductive. Oxide grows spontaneously on contact with air, so an aluminum electrical connection is often unreliable. Welding works, and some (fluoride-based) fluxes can allow soldering, but for crimp connections, you need antioxidant pastes and/or odd mechanical contrivances. Reliable aluminum electrical connections are messy or bulky.
Copper is compatible with a variety of insulation-displacement connection schemes (basically, just a hard clip that dents the copper but cuts through plastic insulation), that stay reliable for years. The clip parts can be made of copper alloys, so there are no dissimilar metals issues. Copper oxide is neither hard, nor insulating (it's a semiconductor), so copper wire just makes a better connection.
Whit3rd
  • 7,177
    Aluminum wiring was (for a short while, and a long time ago) used in electrical drops and branch circuits of homes in the US - [Link](https://www.nachi.org/aluminum-wiring.htm). It's usage was eliminated however, when home fires began happening due to dissimilar metals. – rdtsc Apr 29 '16 at 12:07
    @rdtsc: That is a comprehensive list. I had a coworker from east Germany, and he said aluminum wire was commonly used in houses there. The maleability that is listed in your link was the main problem they had. The aluminum wire "flows" out from under the screw connectors, and the connection gets bad. He said it was not uncommon to plug something in and have the outlet explode because the connection was so bad that the aluminum would get hot enough to vaporise. Flash, bang, replace the outlet if the house didn't burn down. – JRE Apr 29 '16 at 12:29
    I personally experienced a connection fail due to aluminum wiring. Not fun. Just glad I was home when it started throwing sparks everywhere. Did answer the question, "Why is that switch always so warm?" – JS. Apr 29 '16 at 18:22
    In a rush, they simply downsized aluminum alloys used for transmission lines, Bad plan. They have since developed new alloys **specifically for architectural wiring** and outlawed the old alloys. Now it is widely used for big stuff (50 amps and up)... but so feared/shunned for smaller circuits that nobody bothers to stock it. You can use it, but you can't source it. – Harper - Reinstate Monica Apr 29 '16 at 19:31
To put a simple summary to the existing answers:
Aluminum isn't commonly used in wire because while it is a fair conductor, it makes a mechanically poor wire.
Rdtsc gave a very good link in a comment. That list is a run down of all the problems you will encounter when using aluminum wire.
The short of it is that aluminum has poor mechanical properties for use as wire.
A short list of its worst properties:
  1. It isn't ductile enough (fatigues and breaks easily)
  2. It is too maleable (squeezes out and "flows" under pressure leading to bad connections)
  3. It expands and contracts more with temperature changes, which lead to bad connections.
It also has poor chemical properties - the oxidation that Whit3rd mentions.
Oh, yeah. It is also not easy to solder.
Tom Carpenter
  • 63,168
  • 139
  • 196
JRE
  • 67,678
  • 179
Looking at a conductivity table 7075 aluminum alloys have worse conductivity than pure aluminum, nearly half for some of them. Also, Wikipedia says the 7075 alloys are rather expensive (relative to other aluminum alloys), but I don't know how they compare to copper price-wise. These issues together probably explain why despite the 7075 alloys being available for over 70 years now they don't seem to have been used in any electrical applications. As @Harper correctly mentions below, the 8000-series aluminum alloys are the ones usually used in electrical applications.
The current way to make cheap data cables is copper-clad aluminum (CCA). You can help yourself to the ASTM B566 standard and see what's the exact composition of the ideal CCA cable (which doesn't mean that your Won Hung Lo manufacturers will even stick to that.) It's about 10-15% copper and the rest aluminum. For a summary of CCA cable properties from a manufacturer thereof (adhering to the aforementioned standard) see this page, for instance. There's also an ISO 13832 covering CCA, which seems to just incorporate the aforementioned B566 standard when it comes to CCA. UL also references that B566 in their testing services.
Do note however that no CCA cable can be currently and legitimately be advertised as Cat 5e/6. That's because those standards mandate copper; more details over here. Although I know of a ISPs with millions of users using CCA [for final customer-premises connection] and it seemingly pays off for them... even at 1Gbps speeds. But they can afford to test cables to their own standards in-house. Also note that CCA cables also don't conform to some [US mainly] building code standards; the ISPs I made reference to are located somewhere in Eastern Europe (although in the EU); they are also using mostly Huawei equipment.
In contrast, the ANSI/SCTE 100 (2010) standard for 75-ohm coax however allows for B566 CCA cable core (the 10%-copper grade); and it's good for 5MHz-1GHz operation (with -20dB SRL).
I don't know (or care) much about USB cable standards to tell you exactly what they allow or require...
Fizz
  • 14,355
  • 43
    First, if you want UL or inspector approval, you must use 8000 alloys not 7000. These are made specifically for architectural and chassis wiring. Second, you are looking at it conventionally - comparing gage, i.e. Volume. *That only matters in armature windings.* Metals are sold by weight. When you compare by weight, Al is twice as good a conductor as Cu. When you compare by cost, 10 times better, depending on the market. – Harper - Reinstate Monica Apr 29 '16 at 19:42
Cheap 75 ohm coax as used for TV typically has loose aluminum wire braid shield with thin thin aluminum wrap. I think the centre conductor is copper-plated steel.
Nasty cheap stuff, but usable when crimped.
Spehro Pefhany
  • 376,485
  • 842
For very fine 24-gauge ethernet wire, there's just not enough metal there to make much of a difference in total cost of cable fabrication.
