Ever since high school, I've been using the same multi-meter. It works well for low voltage purposes, but I'm scared to use it for anything else (high voltage, unless it's a little zap from an electric fence which I think is high voltage) because I purchased it in 1993 or 1994. It sometimes flashes on/off, and loses its display.
I'm doing some shopping for a new one. One feature about my current one is that I always need two hands to touch the wires because it has leads at the end of it. So I'd like a way to keep the multi meter leads on the wire somehow. I also want one that stands up. There are SO MANY different kinds! I'm looking for some electrical engineering advice on why there is such a HUGE range in prices and what I should buy and get my money's worth. Spending up to a few hundred won't be an issue, but I'd like to know if there is a reason to spend that much. If you know about features that clearly give reason to buy a more expensive one, please let me know.
It might also be good to explain when you'd pay more for a multi-meter for low voltage (or low current) situations, or vice versa, during high voltage (or high current) examples?
Some time ago, I also remember reading something where some multi-meters prevent the end user from damaging the device. Say for example, if you have current running through a circuit, and you turn on the Ohm Meter to measure resistance. In the past, I was always told to turn the power off my circuit when measuring resistance in a circuit because it uses the voltage inside the multi-meter itself for the actual voltage when measuring, and it could be damaged if there was current in the circuit when measuring. I've never made the mistake of doing this, but I would think the newer ones (or more expensive ones) would prevent you from damaging the multi-meter if this ever happened. Especially if they need to pass federal electrical regulations, whatever those are. Seems like a trivial thing to prevent when engineering the product.
Sorry for a loaded question, but I'm sure your answer will result found in plenty of Google search results if you have a good answer.
JustBeingHelpful
  • 335
    Check out the eevblog, Dave has lots of good advice about multi-meters and various comparisons. – George Herold Apr 28 '16 at 20:19
    (step 1. option A.) Start with something cheap and fun. (step 1. option B.) Start with something used and fun. (step 2) Play with it. Put it through its paces. Get a feel for its limitations. Get a feel whether or not these limitations are important for you. (step 3) Buy a high-end multi-meter that fits you. (I'll hazard a prediction that you'll want an oscilloscope by then.) – Nick Alexeev Apr 28 '16 at 20:29
    I am always amazed when people pick one item and wonder why there is a wide range of prices. Why pick on multimeters? You can ask the same questions about cameras, cars, clothes, etc. In general you get what you pay for. For multimeters, higher prices give you better quality construction, more safety features, more measuring functions, etc. – Barry Apr 28 '16 at 20:36
    I'm not sure why this was closed. It seems more about the general differences between price tiers than a recommendation for a specific product. – Adam Haun Apr 28 '16 at 21:45
    In addition to accuracy and stability, professional grade meters will have a higher safety rating. That means that they could survive voltage or current surges that could make a cheap hobby grade meter explode. – Simon B Apr 28 '16 at 22:45
    @AdamHaun: I agree, and have voted to reopen the question – EM Fields Apr 28 '16 at 22:48
What features give reason for such a wide range of prices for digital multi-meters?
THE most important feature is stability aka the voltage reference internal to the device. A lot of really good multimeters use the LTZ1000. Here's a picture: -
Notice how the device is mounted on spindly bits of PCB legs to avoid stress on the die causing random ppm shifts in the output voltage. If you read up on it you'll also find that it has a resistive heat generator and temperature sensor internally so it can be oven controlled.
The LTZ1000 boasts temperature drifts of 0.05 ppm per degree centrigrade. The best "off-the-shelf" device I've found is a maxim device at 2ppm/degC or the LTC6655 also at 2 ppm/degC. Long term stability is also top of the list when it comes the the voltage reference.
Next is very tight precision low drift resistors in fact matched resistor pairs like you can get from Vishay and Linear technology. These are not cheap and turn a run-of-the-mill meter into something like a decent fluke or HP meter.
Forget features - they are ten a penny in comparison.
    I always thought true RMS was one of the pricier features -- or is it just that they put true RMS on the pricier models? – Scott Seidman Apr 28 '16 at 20:57
  • An addition to what Andy wrote, [here's a teardown of a high end thermocouple thermometer (not a multimeter)](http://makersconfidential.blogspot.com/2016/01/teardown-of-fluke-52-ii-thermocouple.html). It gives an idea about the sophistication that's sometimes required to improve precision. – Nick Alexeev Apr 28 '16 at 21:13
  • Very, very nice, and thank you for that Dr. Andy. :) – EM Fields Apr 28 '16 at 23:04
    Your answer is perfectly valid, of course, but I don't get the impression OP is asking about 6.5-digit bench multimeters, but rather the battery-powered portable type. In these cases I would say more important factors are high measurement speed and good accuracy over a wide dynamic range. – Oleksandr R. Apr 29 '16 at 02:39
    Besides the reliability of the readings, it's worth noting that more expensive test gear is often more physically rugged, which is an important factor particularly for field service engineers where the gear comes under more physical stress. – Ian Bland Apr 29 '16 at 08:00
There are several reasons to spend more money on a multimeter.
  1. Safety. If you are doing work involving "mains" electric supplies then you should be aware of "overvoltage categories". If you are only doing portable appliances then "CAT II" should be ok, if you are doing installation work you really want "CAT IV". I would also avoid anything not bearing the brand of a reputable western company as it is all too easy to fraudulantly claim safety compliance.
  2. Features, do you want a current clamp? frequency measurement? an interface to connect to a computer? a crude but sometimes useful osciloscope?
  3. Precision and accuracy, this is where multimeters can get REALLY spendy. The more digits a meter has the more accurate and stable all it's internal components need to get and the more attention needs to be paid to noise and distortion.
Regarding leads/probes, most multimeters use standard 4mm shrouded sockets (some very cheap ones use a non-standard semi-shrouded 4mm, old ones used unshrouded 4mm or even 2mm). The leads that come with a meter will usually be a fairly basic set with fixed, bulky heavily insulated probes and no clips or other accessories. Don't be afraid to buy (or even make) alternative probes/leads that are more suited to your application.
Peter Green
  • 21,158
  • 38
  • 76
    Regarding saftey. In my training they showed us a demonstration video of the importance of CAT IV probes when working in a switchyard. A mannequin with a faulty CAT II multimeter was pushed towards two busbars to measure the voltage until BAM! An explosion of fire, molten copper and mannequin fingers. When the smoke cleared, "he" was completely copper plated and it was doubtful a real person would have survived. Measuring CAT II mains with your Chinese "CAT I" but not really-multimeter is less energetic but can still kill you. – winny Apr 10 '17 at 20:33
Basically, quality, fully characterized and calibrated parts are expensive, there is the labor in calibrating each unit, more expensive units are usually built more rugged too, tougher plastics, better connectors, proper input protection (gets replaced by the dreaded transistor tester), the higher end ones tend to have extra features as well, like statistics and logging.
Sam
  • 3,639
