I have a large anti-static mat lying on the table of my workdesk, which looks like this. Antistatic mat And it's connected to ground through the wall outlet from one point, meaning it's an open-loop: Ground Connection
Let's say I connect myself to the mat using an anti static wrist strap, how is it supposed to help me discharge my static charge when there is no closed loop between me, the mat, and the ground? And lets say I am using a power supply which I am feeding from the mains, and the positive clip of the supply touches the mat accidentally. Wouldn't it be a dangerous scenario for me to be in contact with the mat? I am quite puzzled with the usage of the anti-static mat and nature of the electron movement when there is no closed path. Have a nice day people :)
Dogus Ural
  • 555
  • I don't get:" there is no closed loop between me ,the mat and the ground", but the mat is connected to the ground. – Marko Buršič Apr 27 '16 at 09:06
  • but the ground isnt connected back to the circuit, its a one way trip . – Dogus Ural Apr 27 '16 at 11:46
    You can get mains plugs with only a ground connection, specifically for ESD protection, which would be much safer and more reliable than what appears to be your current (haha) arrangement. – Andrew Morton Apr 27 '16 at 20:44
First, the mat (and the connection to mains earth!!) should have a resistance that is high enough to cause no (extra) harm to you when 'normal' Voltages (let's say up to mains level) are involved. Think Mega-Ohms, and preferably more than one resistor in series to counter single-point-failure issues.
As for the open/closed loop part: think of your body as one plate of a capacitor, the other plate being the earth (in the form of all earthed metal in your surroundings). Now when you touch your mat, there is a closed path. The part that you think of as open (you and the earth) is a capacitor.
Another way to look at it is that for static electricity (as opposed to the more-or-less continuously current carrying electronics we are used to) a closed path is not a requirement. An excess of charge tends to spread itself out and preferably find a place with a shortage of charge to combine with. This is a temporary phenomenon, which lasts until the charges are evened out.
Wouter van Ooijen
  • 48,407
  • 63
  • 136
  • i didnt get the capacitor analogy, is antistatic mat supposed to protect me or the circuit ? – Dogus Ural Apr 27 '16 at 11:29
    The antistatic mat is there to protect the circuit from you. – JRE Apr 27 '16 at 11:30
    ... and the high resistance in the wristband (and the connection from mat to earth) are there to protect you from high currents. – Henk Langeveld Apr 27 '16 at 11:33
    The capacitor stuff is not an analogy, it's real. The charge stored in the capacitance of you with respect to ground is the charge that can rush out and kill ICs if you touch their pins, or can rush out and tweak your finger tip if you touch a filing cabinet. Leaking out (relatively) slowly through a 1Mohm resistor or more to ground is a much nicer process for all involved. – Neil_UK Apr 27 '16 at 11:58
As Wouter says, your body can behave like a capacitor, storing electric charge. A good example of a body storing charge is in the winter, removing a sweater or shuffling your feet across a carpet, then touching a doorknob - ZAP! That tiny blue spark is thousands of volts of static electricity jumping off your charged body. The antistatic mat is very slightly conductive. So if you put on the wrist strap or touch the mat, those thousands of volts are harmlessly coupled to ground. Current does flow - from your body, through the mat, and to ground - simply because your body has substantially more charge on it than ground does, which is an imbalance - and charge prefers to equalize.
If the mat were very conductive, yes. But the mat isn't - it's only very slightly conductive - the equivalent to Megaohms of resistance. And it has to be, to dissipate those thousands of volts safely and slowly. The resistance is so large, that any type of "shorting out a benchtop power supply" would be imperceptible by us.
rdtsc
  • 15,913
  • 30
  • 67
The lumped element model we all learn where current flows in loops and components have no net charge is just that, a model. For many purposes it's a very good model but it doesn't cover every case.
In reality net charges can and do build up on objects. These charges are small but the voltage (potential differences) can be very large. We call this "static electricity".
When two conductive objectsat least one of which is carrying an electric charge come sufficiently close to each other the insulation between them will break down and the voltages will equalise. That breakdown can cause serious damage to electronics.
The point of an antistatic mat or wrist strap is to provide a path to earth that is neither a good conductor or a good insulator. This allows the charge to bleed away slowly and the item to reach an equipotential with the earth without causing damage.
Peter Green
  • 21,158
  • 38
  • 76
The wrist strap (connected to the mat) ensures that you and the electronics (which are on the map) are on the same potential level. Without a difference in level, there's no discharge.
That's all cool, but it only allows the small local system (you + mat + electronics) to be on the same level. That other guy next to you might be on some entirely different level. If he touched your stuff, things could still fry. If all mats are on ground level, they are all on the same level.
  1. the wrist strap pulls your potential to the mat
  2. the ground wire pulls the potential of the mat (and thus you) to ground, where all mats are
Magic Smoke
  • 774
