I need to use this controller with an external applied voltage to control a fan: Currently it is controlled manually by a knob. I need to see the internal circuit to interfere.
How can I find the schematics of this product? Is this a DC to AC converter?
Kevin Reid
  • 7,444
  • 44
user16307
  • 11,802
  • 51
  • 173
  • 312
That looks like an SCR-based speed control for induction motors. They work just like a lamp dimmer, delaying the turn-on during each AC half-cycle, except that they use SCRs instead of a triac (because of the inductive load).
The turn-on of the SCRs are typically done by the rising voltage of the AC line charging a cap on each AC cycle, at a rate determined by the speed-pot (also like a lamp dimmer). There is probably nothing inside there that is low voltage.
To control it from an applied voltage, you could replace the pot/cap delay with some other form of delay circuit, but it would need to be able to trigger the SCRs and survive in a 230 volt environment.
Mark
  • 2,418
    Do you mean the circuit changes the AC amplitude but not the freq? – user16307 Apr 21 '16 at 12:50
  • please see my related new question thanks: http://electronics.stackexchange.com/questions/229730/controlling-a-single-phase-ac-fan-with-a-0-10v-dc-input – user16307 Apr 21 '16 at 17:54
  • Yes. The line frequency is passed straight through, with the duty-cycle (and therefore the average voltage) determined by when the SCRs fire each half-cycle. I will check your related question now. – Mark Apr 21 '16 at 22:07
  • Please see the photos from the circuit here http://electronics.stackexchange.com/questions/229730/controlling-a-single-phase-ac-fan-with-a-0-10v-dc-input II understand why there is full wave rectififer. It is not like a typical dimmer circuit. Is this circuit is similar to http://postimg.org/image/carep5kkx ? Why do you think there is a rectifer? – user16307 May 14 '16 at 14:54
