The method below will tell you if a pin exists on the controller. So, to determine if we're using a 20 or a 28 pin controller, select a Digital Pin that is > 20 and pass it as the parameter to the function below. If it returns true, you have a 28 pin controller. If it returns false, you have a 20 pin controller. I tested this using my MSP430G2553 Launchpad and have the following results:
showPinExistence(2);
showPinExistence(3);
showPinExistence(5);
showPinExistence(6);
showPinExistence(7);
showPinExistence(8);
showPinExistence(11);
showPinExistence(15);
showPinExistence(18);
showPinExistence(21);
showPinExistence(22);
showPinExistence(23);
void showPinExistence(int pin)
Serial.print("Pin ");
Serial.print(pin);
Serial.print(" Exists: ");
Serial.println(pinExists(pin)?"True":"False");
Serial.flush();
bool pinExists(int pin)
bool lowResult;
bool highResult;
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
lowResult = digitalRead(pin);
digitalWrite(pin, HIGH);
highResult = digitalRead(pin);
return lowResult != highResult;
Here's the output for LaunchPad with MSP430G2553 (20 Pin):
Pin 2 Exists: True
Pin 3 Exists: True
Pin 5 Exists: True
Pin 6 Exists: True
Pin 7 Exists: True
Pin 8 Exists: True
Pin 11 Exists: True
Pin 15 Exists: True
Pin 18 Exists: True
Pin 21 Exists: False
Pin 22 Exists: False
Pin 23 Exists: False
Here's the output for MSP430G2553 (28 Pin):
Pin 8 Exists: True
Pin 9 Exists: True
Pin 10 Exists: True
Pin 11 Exists: True
Pin 12 Exists: True
Pin 13 Exists: True
Pin 14 Exists: True
Pin 15 Exists: True
Pin 16 Exists: True
Pin 17 Exists: True
Pin 18 Exists: True
Pin 19 Exists: True
Pin 20 Exists: True
Pin 21 Exists: True
Pin 22 Exists: True
Pin 23 Exists: True
I had to start with pin 8 because it didn't like when I attempted to set 2-7 as output pins :-) Anyway, the point is that you can attempt to set pin 23 as an output pin and write and read its value to determine if the chip you're using is a 20 pin, or if it has more than 20 pins. I don't have a 32 pin chip, but I would imagine that you could test on a pin greater than 28 to make a determination if it is a 32 pin chip.
Now, after ALL that I've said. Since writing this, I discovered that there is now 28pin support on GitHub. I am now using it and referring to pins with their proper P3_0, P2_0 notation instead of directly by Pin number and this seems to be working just fine now.
