Basically I need a low-cost wireless communications module. My requirements would be ~10bit/s , ~2-3m range and up to 1$ for each. Can be receiver and transmitter separately as well. I think it should be working in 433Mhz band.
And suggestions?
Arturs Vancans
  • 765
Chipcon/TI CC110L (transceiver), CC113L/CC115L (transmitter/receiver).
Flexible sub-1GHz radio.
Claimed to cost $1 for pair of chips in volume.
A cheap devkit is available.
Toby Jaffey
  • 28,796
  • 96
  • 150
  • Why the downvote? – Toby Jaffey Nov 25 '11 at 23:14
  • Thanks for bringing these to my attention - amazingly well priced for what they do. Digikey stock them. Look like a nice low cost solution for some applications || You have two down votes for no reason that's obvious - but 3 upvotes including one from me. I gain the impression that there are idio... er ... people wandering around semi randomly down voting with no good cause. Feeling of power perhaps. It takes points off them and you get more points per upvote than a downvote (I think) so all is well. – Russell McMahon Nov 26 '11 at 06:07
  • It is a good choice for a production line, but the package is too small for prototyping. – Arturs Vancans Nov 28 '11 at 13:27
  • @Arturs the devkit is a chip on a PCB, breaking out the SPI bus and power to pins – Toby Jaffey Nov 28 '11 at 22:51
  • @Arturs You are unlikely to find what you are looking for at the price you want. As the volume increases, the price will decrease, but typically so will the part footprint size – Toby Jaffey Dec 02 '11 at 21:47
Please see my answer to Low powered wireless doorbell & door open/closed sensor. I think my Wicked Node / Receiver product is basically exactly what you're looking for.
vicatcu
  • 22,499
  • 79
  • 155
    His target price is "up to $1" which seems about an order of magnitude lower than your offering. Your offering may well be good value for what it does, but his spec is much lower than what you offer and he wants a price to match. – Russell McMahon Nov 25 '11 at 23:57
  • @Russell either I missed that or the price wasn't included in the original question, I'll withdraw my answer. – vicatcu Nov 26 '11 at 05:07
In the past I have used Hope Microelectronics radio modules which are cheap and worked fine.
Before buying the radio modules from personal experiences I would like to suggest you to think about what in your project is essential. If you would like to just transmit some data over a given distance (develop the logic on application layer) then think about how much your time costs and if it is better to spend time to develop the whole logic from data layer up to application layer or is it better to get more expensive module which already has implemented the protocols for two way communication - multiple acces, packet handling etc. and have more time to focus on your application.
Niko Gamulin
  • 229
  • these are also not < $1, but I agree they are pretty nice - also agree that it's non-trivial to build a wireless system from the ground up (i.e. starting with a bare radio) – vicatcu Nov 28 '11 at 16:25
