I was wondering we can easily interface LCD, led an pot etc but I couldn't find way how to record my different voice strings and playback specific string as per commands that given to pic
1You need to add a _lot_ more detail/context/question to this "question". You haven't asked a question, haven't specified which hardware you're using, haven't specified a goal, and so on. – uint128_t Apr 02 '16 at 02:59
Sir or madam I can able to use any pic microcontroller ! But I don't even know what parameters I have to consider for this function ! And for recording I want to use a simple microphones and I don't know in what form I have to convert that for working with pic – user103110 Apr 02 '16 at 03:03
At its simplest, voice recording is simply taking regular analog-to-digital (A/D) samples and saving them in memory (temporary or permanent as the application requires.)
And then retrieving the same set of stored sample values and outputting them through a digital-to-analog (D/A) converter. Or even using PWM (pulse-width-modulation) as as common method of producing analog voltage from a digital output pin.
Some of the challenges are: having enough memory to store the relatively large block of data from a few seconds of audio. And then the problem of maintaining a steady sample frequency/pace for recording and for playing back. In many microcontroller chips, you don't necessarily have complete control over the exact timing of things like A/D and D/A with enough dependability for reasonably quality audio.
That is why there are "voice recorder" chips and whole board sub-assemblies that are pre-engineered specifically for the task. They are optimized for recording, storage and playback.
Here are some examples (just one of many available) * Example voice recorder chips: http://www.digikey.com/catalog/en/partgroup/isd-chipcorder/12724 * Example voice recorder board: http://www.ebay.com/itm/like/252117334430
- 14,382
- 2
- 20
- 37
Thank you Richard sir for very use ful answer ! I don't want to record data in every system but once if I have recorded some strings then only I want these different raws of speech and I want to play these recorded speech at different time ! Like if I press 1 button then play " voice 1 " if I press button 2 then "voice 2 " ! Q – user103110 Apr 02 '16 at 07:12
There are commercial products that do exactly what you are asking for. Examples: https://www.sparkfun.com/products/13720 ; http://www.ebay.com/itm/Micro-SD-TF-Card-MP3-WAV-Player-Board-Module-RS232-TTL-external-IO-C6-6-/301631462414 – Richard Crowley Apr 02 '16 at 23:03
