I want to build a datalogger that has multiple receiver channels that run on serial communication protocol RS232 and then collect the information from the channels in a single storage that would be accessed by another controller whenever it gets full.
I'm using Spartan-6 for the job. I figured I could use Ken Chapman's ultra compact uart to use as receivers and then deploy glue logic to store the data in a FIFO of depth equal to \$noofchannels \cdot (\frac{1}{2}.receiverbufferdepth)+ 4\$ assuming the width to be 8 in all the buffers. Now I have three fillstate signals available from this UART:
- Data Present
- Buffer full
- Buffer half full
and I have to attach a channel ID every time I read data from the receiver-buffer so that the controller reading my FIFO would know which data was from which channel-this thing introduces overhead. I want my algorithm to have lowest overhead as possible as in I want it to attach an appropriate chunk of data (bytes) with each identifier. My baud rate is 115.200 kBd and my clock is 16 MHz. I'm thinking of having 4 receiver channels.
At first I decided to run an FSM that would start every time a half-full signal goes high and read from that particular buffer till its data-present
signal goes zero. Also I calculated that if I keep the buffer depth 4 at each receiver channels and if reading every byte took 2 cycles then I would still have appropriate clock cycles left to read all of the buffers, write it to a single FIFO and ask the controller to read all of it.
Problem with this approach is that I might lose data in case a channel doesn't send more than 7 bytes ( because kcuart6
has a FIFO of depth 16 which I can't change to 4).
Guys I want suggestions for a fool proof architecture that would ensure that no bytes are lost while my glue logic is reading from receiver buffers and also while the controller is accessing my storage memory (because I can't write while the controller is reading my FIFO).
