I am part of a research team looking at the possible effects of EM fields on psychological function. The experiment calls for participants to perform a series of tests while inside a Faraday tent that blocks most of the radio spectrum. We'd like to have the participants perform the same tests inside the tent, but now while being exposed to roughly the same EM fields that are present outside of the enclosure. If we open the door or a panel to allow EM fields inside, then the participants will know. Instead we need the participants to not know whether they are being exposed to ambient EM fields.
Our current plan is to link 2 broad spectrum antennas outside the Faraday tent with a matched pair of antennas inside the tent. We'd have a relay switch in the cable to control the on/off function, and a preamp to slightly boost the signal. I'm not convinced this will work though.
What would you guys recommend? It doesn't have to be a perfect replication, just "good enough." We're most interested in reproducing the 25MHz-3GHz range.
PsiProf
  • 41
    As already answered, it would be cheaper (and simpler) to build one true faraday cage and a fake one, and make sure that the placebo candidates are always given the test inside the fake one. The fake one should be ideally made of styrofoam – MaximGi Mar 17 '16 at 16:53
Accurately reproducing ambient EM fields inside a Faraday tent is going to be very difficult. I know you say you don't need perfection, but using a couple of antennas is probably going to be way off.
An alternative and likely much easier method would be to have two tents, one a Faraday tent and the other similar looking but not - you could cover both in lightweight fabric to hide the distinctive foil/mesh. Move the subject between tests. Or swap the foil door for a fabric one, and use a divider inside the tent so the subject can't see which is which.
If you are trying to reproduce the fields electronically, you'll want several broad-band antennas to cover the full range and you'll want to measure inside and out with a spectrum analyser to verify you've got it right. Some kind of RF graphic equaliser made from amplifiers and notch filters might help tune the system and get them the same.
Jack B
  • 12,167
You could make two panels - one fake (make of plastic or wood) and one real (with a conductive mesh inside). During the experiment, you'd close one panel and leave the other one open. Your subjects won't know whether the panel which is currently closed protects them from ambient EM or not.
Dmitry Grigoryev
  • 25,576
  • 45
  • 106
My intial thought was: No way! Antennas aren't going to be broadband enough.
Then I had a look at some antennas made for emissions testing, and got a big surprise.
Take this one as an example: enter image description here
It has a damned near flat response from about 600MHz to 3GHz.
If you combine that with another that covers from 25MHz upto 600MHz, then you'd have it made.
You'd need two pairs of antennas - a high frequency one and a low frequency one - with one end of each pair inside the cage and the other outside the cage.
I wouldn't bother with combining them into one RF cable - you would need RF filters to combine them on the outside and another set of filters to separate them on the inside.
Just run a cable for each pair, and switch both pairs on or off as needed - that will be cheaper and easier than anything else electronic. Dmitry's suggestion of a removeable panel in the cage would probably still be cheaper.
You might need a small amplifier between the ends of each pair to make up for losses in the cables, or maybe not.
You will need to measure the ambient field outside with a broadband antenna (probably twice, low and high band) to verify the levels. If it is too low inside then you need to add an amplifier to each pair.
You will need an RF analyzer to make the comparisons, and you'll probably want to include that in whatever paper you write as proof of how closely you matched the inside and outside RF levels and at what frequencies.
JRE
  • 67,678
  • 179
