I know we can hook 5v later externally to debounce but still, i heard it works without debounce circuit even if its bouncy. But how can it send signals if there are only output and gnd pins?
Asked
Active
Viewed 4,194 times
They're just mechanical contacts.
Figure 1. Encoder wired to micro-controller with internal pull-ups.
The encoder is probably wired as shown (but I don't know why there are five wires on your diagram). What you can't see is that the internal pull-up resistors in the Arduino have to be enabled for this to work.
Transistor
- 168,990
- 12
- 186
- 385
i think im getting this. So if the SW1 is open, the related pin is 1. But if the SW1 is closed, the pin is 0. Am i correct? There are rotary encoders in the market which has a +5V, A, B, C pins like KY-040. If i use it, i wouldnt need to activate arduino's built in pull up resistors right? I think Ky-040 has its own pull up resistors right? – Çay Öncesi Mar 13 '16 at 17:58
KY-40 is a rotary switch on a small PCB with room at the back for pull-up resistors. If you are lucky they are present ;) – Wouter van Ooijen Mar 13 '16 at 18:15
@WoutervanOoijen what did you mean by present :D So they have pre soldered pull up resistors right? – Çay Öncesi Mar 13 '16 at 18:44
@ÇayÖncesi: I am not familiar with the Ky-040. Some encoders are optical and they use a disc with transparent and black zones on them. These use LEDs and sensors to detect position and so never wear out - unlike your mechanical switch. The LEDs need +5 V and GND. – Transistor Mar 13 '16 at 19:20
