I am trying to drive an ultrasonic "tweeter" for a wearable research project. Compared to a normal speaker, the tweeter has a very high impedance, upwards of 4kohm. As a result, it requires a very high voltage to produce appreciable power, but the RMS current draw is a few mA per tweeter at most. I've been using the LTC6090 op-amp, which accepts up to +/-70V at the rails and works very well with the frequencies I'm interested.
Until now I've been using a janky combination of an off-the-shelf 12V voltage regulator and an LT1054 voltage doubler to produce +/-22V at the rails, but I'd like to do better if possible. There seem to be a world of options out there, but here are a few I'm considering:
  1. Use the LT8331 to produce a voltage around 135V using the application note on page 22 of its datasheet, then use something like this unipolar to bipolar DC converter with some heavy-duty BJTs to turn this into +/-65V. Or I could just put 0/135V at the rails and bias the 5V signal using a voltage divider?
  2. Use the LM2587 flyback regulator in a configuration similar to the one shown to produce +/-70V. This one seems viable, as the advertised max output voltage is 60V, but I'm not sure if I could simply change up the component values here to produce a higher output voltage.
LM2587 application
  1. Use an LT1054 to turn +5V into +/-10V and then turn those into +/-70V with two separate boost ICs.
For some of these, I might need to boost in several stages; I have a 5->35V regulator that I can use as the input to another stage. This may be inefficient but my application is not power intensive, requires very little current, and is mostly a proof-of-concept, so this is not a problem for me at this point.
Essentially, I would like to know the best way to go about doing this. It's unlikely that I'm the first person to be faced with this problem and I'd like to try to avoid tunnel vision or reinventing the wheel in ways that are likely to be inefficient, unreliable, or dangerous. I would appreciate any insight, from high-level design advice to specific components or topologies that could be helpful.
I am new to this stackexchange so please forgive the lack of links to component datasheets, I don't have enough rep to post them.
Ian Reynolds
  • 105
    Why can't you operate the amplifier at a low voltage, e.g. 5 V, and use a transformer for boosting the signal amplitude 10-20 times? – jms Mar 10 '16 at 04:18
  • I have to admit I haven't looked into doing it that way. I steered clear of transformers on the first iteration because I couldn't find anything very compact, but it might be time to take a second look. – Ian Reynolds Mar 10 '16 at 04:24
    At ultrasonic frequencies (what freq. are you planning to run this mosquito repeller at?) the transformers do, fortunately, get *far* smaller than anything you could use at 50/60Hz ac mains frequency. Another option you may not have considered yet: You could build a buck-boost topology converter with a center-tapped inductor. Let one end of the inductor feed your +70V rail, the other end feed your -70V rail, and the center-tap gives a "signal ground" (do NOT connect it to the power supply GND) that you can couple your input signal to. – Robherc KV5ROB Mar 10 '16 at 06:15
  • @IanReynolds : that is, after all, exactly what your switching converter does, and at a similar sort of frequency. So you need a roughly similar inductor either way... –  Mar 10 '16 at 12:29
  • @RobhercKV5ROB the device is designed to output broadband signals, like chirps and clicks, at a range of around 30-80kHz. I'm not sure how to buy off-the-shelf transformers, especially really small ones designed to be surface-mounted. Is [this](http://www.mouser.com/Passive-Components/Transformers-Audio-Signal/_/N-5gbg) a good place to start? The frequency ranges look right and I can pick an impedance ratio that suits my needs. – Ian Reynolds Mar 10 '16 at 13:23
  • @Ian Yes, I think most of us shop there, at www.digikey.com or at www.sparkfun.com for similar components (though I think sparkfun is mainly for finished modules, but I could be wrong... haven't used 'em much myself) – Robherc KV5ROB Mar 10 '16 at 13:39
  • Also, to add to my first comment, while I mentioned using a buck-boost topology there, I think a simple boost topology, with center-tapped inductor, could work as well. Still with the same caveat of having an 'isolated signal ground,' of course. - Either way, you're basically creating a +140V output, a +70V output to use as "signal ground", and a GND output for your -70V. – Robherc KV5ROB Mar 10 '16 at 14:03
  • Your number 2 option can work well. You may need to figure out how to wind your own transformer. Keep the duty cycle to around 50% which mean a winding ratio of 1:(12+12) for +/-60V output. – rioraxe Mar 11 '16 at 06:55
  • I would use the LT8300 as suggested in the LTC6090 datasheet as it is capable of significantly higher drive than the LT3511 (See the datasheets for details). The minimum load for the flyback (which is necessary for operation) may be just the amplifier so you may not have to waste any extra secondary energy. Do carefully follow the flyback converter datasheet for successful realisation. A nice thing about Wurth is that their entire standard magnetics catalogue is available for integration into LTSpice so you can simulate against the manufacturer model. – Peter Smith Mar 12 '16 at 16:50
  • Welcome to the site! This is a well-written question. – Adam Haun Mar 15 '16 at 14:35
I would strongly recommend against attempting any sort of audio output transformer to boost the output of the op amp like is being suggested in the comments. Don't get me wrong, it is a perfectly valid and frequently used technique. In reality, it's just a kind of impedance matching, and impedance matching transformers work great for this, and let low impedance amplifiers drive much higher impedance voice coils by effectively stepping up the output wave form.
The problem is that none of that works at all in your application because you're not driving a voice coil, you're driving a piezoelectric ultrasonic transducer.
This is a fairly important distinction that you should be aware of, because many of the normal techniques that work to drive traditional speakers are not applicable to your situation. Voice coils are deflected by current flow and their impedance is resistive and inductive in nature. Your ultrasonic transducer is none of those things. Its impedance is entirely capacitive and open circuit to DC. It's actuated by charge difference between its plates, not current. So effectively, it is deflected by voltage directly. You actually need polarity, and coupling it via a transformer will cause you to lose this, so you'll also have to use a synchronous rectification stage to restore the polarity on the output of the transformer. This isn't a problem if driving speakers, but it matters with this kind of load. You need to drive it by directly pulling plate charge out or into it, and the way you should do this is the way you were planning to do it from the start.
You have a couple options there though:
  1. You can use a high voltage op amp with wide supply rails, OR
  2. Use a low voltage op amp controlling push-pull output stage tied to high voltage rails.
I think 1 is going to have the best performance as well as being simpler and easier, especially considering the nature of the signals you will be working with. Chips, clicks, various other things need to be amplified and (at least, I would assume) with minimal distortion. Option 2 is really only when you need the performance you can only find from a lower voltage op amp, but since there is an op amp that is specifically designed for your application (amongst others) and we are really only talking about maybe 80kHz tops, I don't see a reason to attempt option 2. I suggest option 1. The LTC6090 works very well for the exact thing you need to use it for. Down to the thermal pad area, everything is accounted for.
As for obtaining the rails, the datasheet for the LTC6090 actually contains a couple of schematics dedicated entirely to producing ±65V or ±70V rails for it. You can use them or not, but the topology is the point. In my opinion, a flyback converter is definitely your best bet. 5V to 70V is really too high of a ratio for a boost converter. 135V is pushing it even more - the LTC8331 is great part, and it can probably make 135V from 5V, but it won't be efficient or pretty. And I don't think tapped inductors are all that available for making the virtual ground. It will be simpler, cheaper, and much more practical to simply use a flyback converter with two output windings.
Don't be intimidated by flyback converters - they're just inverting buck boost converters. I kid you not. Look at the circuits. They're the same circuit, the same converter, the same thing. The only difference is the flyback has two or more windings on the same core for its inductor. And the diode might be one way or the other depending on the polarity you want. Honestly, I would recommend simply using the LTC3411 as suggested in the LTC6090's datasheet. You might want more current though, which is what the LTC3412 is for - it's just an LTC3411 with twice the current capability. Unfortunately, you should probably go with the somewhat pricey ($6 in single quantities) Würth transformer Linear suggests in their datasheet. Flyback transformers don't really need a proper transformer and just a coupled inductor, but there are few coupled inductors with 3 windings, and I doubt any of them are rated for 100+V (you want some headroom). The Würth transformer is small, surface mount, and can safely handle 150V on each secondary winding. You can't go wrong with Würth, but they'll make you pay for the privilege.
I know you want to probably keep the BOM down, but trust me, it will be worth the time saved and lack of headaches and complications to just kind of 'copy and paste' an application schematic from a converter like the LTC3411/2. Linear's switching parts are also the best and easiest to use (and also the most expensive sadly) and I usually suggest starting with a linear part. Once you're more experienced and comfortable with switching converters, TI is good too and much cheaper, though often will not be quite so easy to use.
You should be worrying about those ultrasonic chirps and hoots and what not, I think this is one of those situations where it makes sense to pay a little more to just not have to deal with the power supply so you can deal with the thing you're actually doing. If you can, just grab that Würth transformer, follow the schematic on page 22 of the LTC3412 datasheet, or there is a table of transformers and their potential outputs on page 10. The circuit will work fine with 5V input but with reduced output power, you only need to adjust the EVLO divider for 5V (or just tie it directly to VIN).
metacollin
  • 27,884
  • 64
  • 119
  • This is an excellent answer and I can't thank you enough for taking the time to write this out — I have not been thinking of the load as capacitive at all (even though the manufacturer has even provided a cryptic hint about the impedance decreasing with frequency, yikes!) so you have likely saved me a lot of headache. I'll probably just go with the schematic from the 6090 datasheet. Buying a $6 transformer is not exactly going to break the bank as we only need to build one of these for the time being :) Thanks again! – Ian Reynolds Mar 13 '16 at 03:27
    @IanReynolds - Always make at least 2 prototypes! That way, when you asplode the first, you can work with the second. I've been there. – Connor Wolf Mar 13 '16 at 03:43
