A computer SMPS is capable of providing stable power supply to multiple devices like hard drive, CD/DVD drive, etc....
Is it possible to convert an old SMPS to power a tablet/cellphone?
What modification should I do an SMPS to serve 3.1 AMP 5.0 volt to charge 7200 mAh 10 inch tablet device?
I would like to convert a 450W PC ATX computer power supply with an input voltage of 5 AMP 230 volt, the output I want is 3.1 amp 5.0 volt which can be connected to a cellphone or tablet with a 2.0 mm DC pin
The IC which I see inside is WT7520.
I can see the high power components F12C200, D13007k, C5027-R attached with heat sink.
The label sticker provides the following input/output:
INPUT: AC230V 3.5A 50Hz
OUTPUT: AC230V 1.5A 50Hz
But I don't know what is the current provided to hard disk power plug.
