Consider the following circuit, which multiplexes the d0
and d1
inputs to the y
output in one clock cycle (i.e., double data rate, DDR).
Which may be the result of synthesizing the following Verilog code:
module ddr_mux (
input wire clk,
input wire d0, d1,
output wire y
reg q0, q1;
always @(posedge clk) q0 <= d0;
always @(negedge clk) q1 <= d1;
assign y = clk ? q1 : q0;
endmodule
I have the following timing requirements:
q0
must not change while theMUX
select input is at0
q1
select input is at1
In other words,
y
must have at most two transitions per clock period.
If the synthesis and timing analysis tools do not know these requirements on the y
output, they have the freedom to implement the circuit with an arbitrary timing relationship between q0
, q1
, and sel
. Here is an example of how this could go wrong:
And here is the desired behaviour:
How do I correctly express this in the form of SDC constraints to be read by Cadence synthesis and timing analysis tools?
