59
I'm a beginner in hobby electronics and I am wondering why digital oscilloscopes are still so expensive?
In times of cheap GHz CPUs, USB 3, ADSL modems, DVB-S receivers, blu-ray players which all of them have remarkable clock frequencies/sampling rates it makes me wonder why a digital oscilloscopes which is capable sampling signals of a bandwidth of 10MHz are still very expensive, 100MHz is already high-end.
How can this be explained?
What differs the ADC from an digital oscilloscopes from one of the devices mentioned above?
MRalwasser
  • 739
    In the server hardrive market High end SAS drives are almost $200 for 78GB despite typical consumer drives being <$100 for a TB. Consumer grade technologies have different tolerances, requirements, and purposes, not to mention different production scales. Its shouldn't be surprising that the same basic technology can have such differing costs just due to variances in requirements. That being said, DSO's are a lot cheaper now then they could have been, due to mass market utilization of ADC's (albeit consumer grade) which allows more R&D money to spill over to high end development. – crasic Nov 09 '11 at 03:33
    I don't think they are expensive at all. Oscilloscopes costs a fraction of what they did 10-15 years ago. You can even get a really crappy one for the price of a blu-ray player. – morten Nov 14 '11 at 21:01
  • You can now get a digital oscilloscope for under $100...http://www.seeedstudio.com/depot/dso-nano-v2-p-681.html?cPath=174 Not the fanciest one in the world, but suitable for a hobbyist to start off with. – Grant Aug 20 '12 at 14:21
    The biggest factor is much lower production volumes. – mikeselectricstuff Nov 08 '11 at 21:33
    200khz is useless for much beyond audio. – Matthew Whited Aug 23 '16 at 19:58
  • First of all, none of the devices you mentioned have an ADC that samples at 10MHz, never mind 100MHz, few of the devices mentioned even have an ADC, heck I'm not sure any from your list do. Secondly, ADCs with such a high sample rate are actually very difficult to make, and are specialized devices, many companies design their own ASIC. And third, there is a lot of data in the path, that has to be stored, segmented, processed and displayed, in real-time, that's a difficult and expensive problem. – Ion Todirel Apr 12 '20 at 12:01
6 Answers6
39
I'd firstly agree with other posters as to economics of scale. Consumer devices are produced in the millions whereas such a market does not exist for digital oscilloscopes.
Secondly, oscilloscopes are precision devices. They need to undergo rigorous quality control to ensure they live up to expected standards. This further increases costs.
As for bandwidth. The Nyquist criterion states that the sampling rate should be at least twice the frequency you want to measure. But even at twice the rate, it is terrible at best. Consider the following pictures:
The graph captions tell the story. You need to exceed the specified bandwidth by a great amount in order to gain an accurate representation of the square wave input signal (high frequency harmonics). And greater bandwidth = greater cost.
In the end the precision, bandwidth and limited production quantities that drive up prices.
Konsalik
  • 1,885
    Well, the linear interpolation doesn't help.. – endolith Nov 08 '11 at 23:03
    "by a great amount" is quite wrong - by 2x precisely, that's what's important about the Nyquist criterion. – James Nov 08 '11 at 23:59
    @Autopulated, I cleared it up for you. Nyquist is still correct but I was specifically referring to that square wave. You would need an infinite bandwidth to capture it perfectly so we are loosing information and cannot sample all the higher order harmonics as our sample rate is bellow their respective Nyquist rates. – Konsalik Nov 09 '11 at 00:17
    A 20MHz square wave has harmonics much greater than 20MHz. So isn't using a nyquist frequency of 40MHz for a 20Mhz square wave not correct? What happens when you use a 20MHz sine wave instead? – Doc Nov 09 '11 at 14:26
    @Doc: In most application domains, perfect sine waves are the exception rather than the rule. If one were to sample a 19.9MHz sine wave at 40MHz, and then pass the reconstructed wave through a 19.91MHz brick-wall low-pass filter, one would get back the original 19.9Mhz wave. Without a reconstruction filter, one would see a 19.9MHz wave superimposed on a 20.1Mhz wave, which would appear as a 20Mhz wave ring-modulated at 100KHz. Note that scopes generally do not have perfect filtering, both because it would be expensive, and because ... – supercat Aug 20 '12 at 15:01
    @Doc: ... a brick-wall filter is not always the optimum thing for capturing a wave's "visual" shape. For example, passing a perfect 10Mhz square wave through a 45Mhz brick-wall filter will yield a wave with a fairly substantial dip in each of the areas that should be flat. If one didn't filter the square wave before capturing it at 100MHz, so that each wave was simply high five samples and high low samples, a simple plot of the data points would look more like the original than would a plot of the filtered points, but a brick-wall reconstruction would look much less like the original... – supercat Aug 20 '12 at 15:26
    ...than would a brick-wall reconstruction of the filtered wave, which in turn would look less like the original than would a simple connect-the-dots plot of the unfiltered data. – supercat Aug 20 '12 at 15:30
  • Another way of putting supercat's argument might be that, when it comes to 'scopes, discussion of Nyquest tends to be misleading. Nyquest and filtering strategies are about what you need to record a signal you have already characterized (i.e., you know the highest harmonics you need to record), but you're typically using a 'scope to _characterize a signal about which you don't know all the details_. In other words, if have the information you need to do a perfect sampling of the waveform, you usually don't to be looking at it with a 'scope. – cjs Aug 12 '19 at 01:41
25
Economy of scale -- the other items you mentioned are consumer devices, manufactured in the millions. Oscilloscopes will be manufactured in the thousands (or less), which makes a huge difference in amortized R&D, BOM (bill of material) and assembly costs.
tcrosley
  • 47,708
  • 161
  • I learned that the ADC is one of the expensive component of a DSO - but why can't the ADCs of such consumer devices be used in oscilloscopes? – MRalwasser Nov 08 '11 at 21:34
    COnsumer ADCs tend to be very tuned to their application's requirements, in particular they often don't have the good DC performance or absolute accuracy needed for a scope. – mikeselectricstuff Nov 08 '11 at 22:24
    @MRalwasser - They could, but if you want a decent bandwidth rate you need a fast ADC. For example, your average 100MHz DSO might have a 1Gsps ADC, have a look at the prices for these. Here is a random [example](http://uk.farnell.com/texas-instruments/ads5400ipzp/ic-adc-12bit-1000msps-100htqfp/dp/1815781) (you *can* get them cheaper, but still in the hundreds) – Oli Glaser Nov 09 '11 at 00:49
  • So.. basically, they've created less supply, so they can charge more for it. That's a bit criminal, imo. – kevr Nov 23 '20 at 04:13
21
Lower production volumes are a major cause and secondly, you're buying test equipment which is something special. If you only look at the teardown of a cheap DSO like a Rigol DS1052 you will see what's required just to make a low-entry scope. They have 5 dual ADC's (overclocked, so that already reduces pricing!). If those ADC's were $4 each (a random guess, very large quantities), that's already $20 on ADC's. Digital circuitry to drive and read the ADC's are probably very expensive too (FPGA, CLPD, DSP proccesors aren't cheap) I guess the analog frontend adds to like 25$ easily too. Then there is PCB costs, manufacturing, the case, color screen, front-panel board, power supply, boxing, shipping and paying engineers to design/support it. I can't see how they would sell that product for even less. I think that the DS1052E is about 300 euro's here in Europe.
If you look at the teardown of a much more expensive DSO like Agilent 3000X, I think a large amount of the price goes into the production and design of those ASIC chips. ASIC chips are custom designed digital IC's. It's like an FPGA, but with more speed and 'space'. Imagine you design a chip completely acustomed to your product. I am sure that will cost them a lot of money to get off the ground.
Coming back to the 'versus PC' performance: those ASICs process 1M waveforms per second. To put that into perspective, if you have a processor running at 3GHz it would only have 3000 clock ticks between each trigger point to process the waveform. How many points do you think is in a waveforms memory? Well it may be 4K. That would mean the proccesor needs to process 4/3 of a sample in 1 clocktick. No way! Furthermore, consumer PC's and their processing speed are built around and operating system, PCI-e busses, and very complex high-end stuff. Older high-end scopes were using PC boards for post-analysis. They aren't fast enough to process, display and analyse waveforms at the same time.
Also note that this scope has a maximum (real-time) sampling speed (so it's no tricked with software) at 4GSa/S. If you include features like serial protocol triggering (i.e. you send the character 'A' over a serial bus it will trigger the scope), you just need custom hardware to do it. Of course, the displayed scope costs $12K (gets you a decent car now adays too!) but apparently engineers require these tools, and this is what it takes to make it happen.
Hans
  • 7,238
    How do you define **waveforms**? From my perspective, a 1 channel DSO has a specific sample rate, and there are no (2 dimensional) "wavesforms" per tick, but exactly one sample value, so a modern cpu would be capable of dealing with a sample rate of 1M/s. – MRalwasser Nov 09 '11 at 19:35
I bought a Rigol DS1052E oscilloscope, on the basis of Dave Jones eevblog #37 tear down, in May this year for £257.76 + £31.20 postage, tracked, (well worth it to watch it approach across the world, took two weeks) from BestOfferBuy. I am delighted with it, and I see it is now priced at about £215, exc postage. There is another version with a 16 channel digital analyser included.
I have no connection with Rigol or BestOfferbuy except as a delighted customer.
This press release allegedly describes how they can produce it so cheaply without sacrificing quality:
Outsmarting local competition wins global recognition
The late Speaker of the U.S. House of Representatives Tip O’Neill once said, "All politics is local." Rigol Technologies, a Beijing instrument maker, may have written that statement’s corollary: "All business is local."
Founded in July 1998, the company launched its first product -- a virtual oscilloscope designed to work with a PC -- in less than a year. Its success led the company to develop complete, standalone oscilloscopes as well as to branch into other instrument-related areas. In 2006, the company introduced the DS 1000C digital storage oscilloscope, which won wide acclaim in China.
The scope was a breakthrough for Rigol, providing a small form factor, deep memory, wide bandwidth options, and low price. And its success also brought a common form of flattery: imitation. By 2007, Rigol was the No. 2 DSO manufacturer in China, producing over 40,000 DSOs a year. The same year, copies of the scope from a few Chinese manufacturers also began to appear. In China, where intellectual-property protection is still maturing, the practice of "knocking off" someone else’s design was common. (Rigol has since successfully sued the copyists.)
The rapid copying of Rigol’s products made the company examine its business strategy. Getting out of the low-end market was not really possible, given the importance of the education market to Rigol’s current and future business plans. The other possibility was to find a technical way to distance itself from the copyists. Wang Yue, the founder and president of Rigol, as well as the key system architect for most of the company’s major instrumentation platforms, decided to use Rigol’s R&D resources, buying power, and low manufacturing costs to create a product that even those who copied it couldn’t undersell.
Because Rigol uses off-the-shelf components, it is the world’s largest purchaser of commercial ADCs and other DSO parts. So it used this purchasing power to reduce parts costs. Believing it could double volume again as it pushed price down, the R&D team set out to create a fast turnaround project with a one-year product design cycle. The manufacturing team created a way to increase volume at little extra cost and at an overall lower average cost.
The result was the DS 1000E product group. The line not only is succeeding in its home market, but in Europe and the Americas as well.
Kevin Vermeer
  • 19,989
  • 57
  • 102
Harry Weston
  • 2,170
  • This doesn't seem to answer the question of why DSOs are so much more expensive than Blu-Ray players. – cjs Aug 12 '19 at 01:32
I don't know too much about the politics and business (low production volume and precision requirements seem like reasonable explanations), but I know that analog to digital converter chips can get very pricey. On Digikey, they can run into the thousands, and the most expensive chip is $14,000 for one single channel ADC!
The Wikipedia article on ADCs explains how these chips get so expensive:
Direct conversion is very fast, capable of gigahertz sampling rates, but usually has only 8 bits of resolution or fewer, since the number of comparators needed, \$2^N - 1\$, doubles with each additional bit, requiring a large, expensive circuit.
Cheap chips rely on converting a voltage measurement to a time measurement, like charging a capacitor and measuring the time. However this limits the speed at which the chip can run. The fastest ones run in parallel using one voltage comparison circuit for each voltage level. This means a 10-bit ADC needs \$2^{10}=1024\$ comparators per input, plus circuitry to convert each to a binary number. This all means the chips need large areas of silicon, which drives up cost incredibly rapidly (ask Intel). I'm sure the precision requirement also ramps up cost, and maybe also issues of input capacitance when the signal goes to 1000 internal circuits.
The faster (GSa/s) chips tend to be this kind of high performance ADCs. So for a gigasample 4-channel oscilloscope, these could easily add $4,000 to the price tag.
stevenvh
  • 145,145
  • 455
  • 667
Leigh
  • 41
Compared to analog scopes, digital scopes aren't expensive at all. I don't think it's the technology so much as the low-volume market, like tcrosley just said. Even if you built the scope with the most mass produced parts available, there would still be the non-recurring engineering (NRE) cost in designing the thing, and it's basically the NRE that you're paying for.
JustJeff
  • 19,163
  • 75
