As i understand, using this circuit:
current
Will cause the current to go right through the POT and resistor, which will generate a lot of heat. Is there a better way to use current limiting with LM317 without all of the current passing through the resistor? (Without spending a lot of money for a high power resistor/POT which can handle over 5 amps)
if anyone could draw an example circuit i would appriciate it!
I wanna be able to set a limit from 10mA to 1.2A, the output of the current limiter goes directly into another LM317 for voltage regulation. Input voltage i'm going to use is 15V.
This is how the completed project "should" look like: complete The output voltage is not that important for me, as long as i can get from 1.25 - 10v. I just want to avoid the heat from the current limiting part.
Xane
  • 473
  • Edit again and explain your requirements. Input voltage, min current, max current. – Transistor Feb 04 '16 at 22:49
  • Done, sorry for the lack of info :) – Xane Feb 04 '16 at 22:53
  • ... and what output voltage range are you hoping for on the finished project? (You may lose too much on the too series regulators.) If you supply all the relevant details someone may come up with a better solution for you. Pop the details into the question (not in the comments). – Transistor Feb 04 '16 at 22:56
  • Added some more info. – Xane Feb 04 '16 at 23:02
  • Your second schematic has the same problem as the first, the current will still go through r4 and r3 and u2. – Passerby Feb 04 '16 at 23:37
See LM317 based power supply with current limiting on SE and alexan_e's answer. Read through all the answers and comments as there were some good suggestions. The circuit avoids high-current pots by using some trickery.
Source: ON-Semi datasheet.
Other circuits from the web:
Figure 1. Negative rail supply for first option.
Since you have plenty of transformers you can use a second one to generate the negative supply. A 6 to 9 V transformer would do the trick and I don't think you would need a regulator. A 100 mA rating would be plenty.
Understanding the constant-current source
Figure 2. Constant current portion of the LM317 based power supply with current limiting.
As you determined in your OP, there's a problem using a variable resistor in a current source mode because all the current goes through the variable resistor. This circuit addresses that problem.
  • \$R_{SC} \$ is a fixed resistor and sets the short-circuit (SC) current limit. The LM317 Vout is \$ V_{ADJ} + 1.25 \$ so if we want 2 A max then 0.65 Ω would do the trick.
  • Q1 forms a simple constant current generator - I don't know what current it will settle down at. Maybe someone can enlighten us in the comments but let's assume it's around 10 mA going to the -10 V rail.
  • D1 and D2 form a little constant-voltage drop. Whatever the voltage is on the right of \$R_{SC}\$ (\$V_{IN2}\$) the bottom of D2 will be 1.4 V (2 x 0.7 V diode drops) below \$V_{IN2}\$.
  • By adding the 1k pot across the diodes we can adjust the voltage on \$ V_{ADJ}\$ from Vin2 to 1.4 V below \$V_{IN2}\$. Remember that we only need to get \$ V_{ADJ}\$ 1.25 V below Vout1 to shut the output off.
Time for some calculations:
\$R_{sc}\$ = 0.65 A. Pot wiper at top. \$V_{OUT}\$ feeding a low resistance load to make sure we're in current limit.
  • \$V_{OUT1}\$ will increase until the voltage across \$R_{SC}\$ is 1.25 V. This will happen at 2 A.
Pot wiper now moved to centre.
  • Because of the Q1, D1, D2 arrangement the voltage on the pot wiper will be Vin2 - 0.7 V.
  • The output will settle when the voltage drop across \$R_{SC}\$ = 1.25 V - the 0.7 V = 0.55 V. From Ohm's Law, \$ I_{RSC} = \frac {V_{RSC}}{R_{SC}} = \frac {0.55}{0.65} = 0.85~A \$.
  • The further down we adjust the wiper the more the current is limited. Note that in this arrangement the current will be zero before the end of travel of the pot. Adding a series resistor at the bottom between it and the D2 junction will fix this.
simulate this circuit
Figure 3. Using full span of pot by addition of R1.
  • The voltage across D1 and D2 is 1.4 V, as discussed above.
  • With wiper at top we get maximum current, as discussed above.
  • To use the full span of the pot we want 1.25 V on the wiper when it is a bottom. Without R1 we'll have 1.4 V. \$ \frac {1.25}{1.4} = 0.89 = 89\%\$. So we need the 1 kΩ pot to be 89% of R1 + R2. We can get this if we set \$ R_{TOTAL} = \frac {1k}{89} \cdot 100 = 1,123~Ω \$. So R1 = 120 Ω should do the trick.
Calculating \$ R_{SC} \$
The LM317 can handle 1.5 A max. That's your short-circuit current. \$ R_{SC} = \frac {V_{ADJ}}{I_{MAX}} = \frac {1.25}{1.5} = 0.83 Ω \$. 0.82 Ω will do or some parallel combination.
The power rating of the resistor is given by \$ P = V \cdot I = 1.25 \cdot 1.5 = 1.9~W \$.
Transistor
  • 168,990
  • 186
  • 385
  • Thank you for the info, I have checked in the datasheet of LM317 and found the "Lab Power Supply Circuit", the problem with that circuit is that it needs one rail with negative voltage, i have checked a thread here about a guy who asked what was the best way to get negative voltage and he was using a center tap transformer which i don't have. I don't know how to get negative voltage without a center tap/buying additional IC.s. I do have a lot of transformers laying around but no one with a center tap. – Xane Feb 05 '16 at 18:58
  • See the update. – Transistor Feb 05 '16 at 19:21
  • Thank you very much, I've been looking for this. Gonna try it out in a simulation :) – Xane Feb 05 '16 at 20:00
  • http://i.stack.imgur.com/oLuPR.jpg quick question, after Vout1 there is a resistor called "RSC" do you know what that stands for? Thanks! – Xane Feb 05 '16 at 20:15
  • Also, won't the current go right through the RSC resistor? – Xane Feb 05 '16 at 20:34
  • Further explanation added. – Transistor Feb 05 '16 at 21:11
  • Thank you for the explanation. i got most of it, Tried to emulate it and it worked fine, except that no matter how i do, the current still goes through the RCS resistor. the first transformer is for around 20v and the second one is for the negative voltage (around 9 volts). The part i didn't understand was: "Adding a series resistor at the bottom between it and the D2 junction will fix this" https://i.gyazo.com/a2cffd5d41c60e092a207c566812311a.png The voltage before the RSC resistor is 1.25 volts. – Xane Feb 05 '16 at 23:29
  • (1) All the current is supposed to go through \$R_{SC}\$. It's value is calculated as shown to set the maximum current out of the device. (2) I'll sketch the resistor / pot bit and add it to my answer in a few minutes. (3) 100 Ω is a bit too low for the pot. 1 kΩ would be better. – Transistor Feb 05 '16 at 23:35
  • Thank you, and just to clarify, since The current goes through The resistor and lets say that i want a limit from 1-10 amps. I need to get a resistor/get a few high powered one in parallel so that thet can handle The high current? – Xane Feb 05 '16 at 23:40
  • The LM317 is limited to 1.5 A max. See the data sheet. "_I wanna (sic) be able to set a limit from 10mA to 1.2A._", is what you asked for. (I forgot the limit was 1.5 A. I've shown a calculation for 2.0 A in my answer.) Rsc calculations added. – Transistor Feb 06 '16 at 00:01
  • I see you've asked four questions on this site and I don't think you've accepted answers for any of them. You might think about fixing that given that people have given freely of their time to answer your questions. – Transistor Feb 06 '16 at 00:07
  • I will do that. Thank all your help and tips. Cheers – Xane Feb 06 '16 at 00:11
  • So back again, this is prolly my last question before i start to built this thing, thanks to all of your tips i have managed to get everything that i want working. Now the last thing that i want is to figure out how to increase the current from 0 - 1.2A (max of LM317) to around 3A. I'm sure that a 2N3055 can do this, but i don't know where to put the base/collector/emitter with both current limit and voltage regulation. Tips? Sorry about the chaos wiring of the circuit: https://i.gyazo.com/e179a28b68ed9a7f679253f2ee448a48.png – Xane Feb 15 '16 at 13:11
  • I just received my order of a few 2n3055 transistors, as soon i figure out how to wire them I'm good to go (i hope). I tried a few combinations with the collector in different places (simulation only), and it just wouldn't work as i wanted it to. With a single LM317 you can just wire the base at the vout, collector before the vin, and emitter as output and it works but with current limiting also it's harder hmm. – Xane Feb 18 '16 at 19:16
  • Hello again, i just tried a few thinks for fun and i noticed that if i use a 2n3055 i can use a current limiter this way: https://i.gyazo.com/a496d875fca14a47eaa59ce03b6db175.png In the simulation almost no current goes through the pot, i don't know if this would work in real life but i guess so, can anyone see anything bad about this layout? Is there a reason why i shouldn't be using it? – Xane Mar 07 '16 at 21:26
  • is this a *limiter* or constant current? – johny why Jun 05 '22 at 18:31
  • @johnywhy, you will need to be a lot more specific in your question. What are you referring to? There is the datasheet schematic and my Figures 1 to 3. What part of the answer do you not understand? – Transistor Jun 05 '22 at 18:50
You have problems and you need to listen-up. Your lower circuit shows a 15V RMS supply that is bridge rectified and smoothed. This produces a nominal DC level of about 20V. From your question you may want to push out 1.25V at 1.2A.
From this alone i can tell you that the heat dissipation in the LM317(s) is going to be: -
Power = volts dropped across LM317 x current = (20 - 1.25)V x 1.25A = 23.4 watts.
The only way you can avoid this is by using a switching regulator that is configured to produce a constant current. Yes it will be noisy and yes you can make a basic switching circuit quieter but how far do you want to go?
    Yes iam aware that teh LM317 is going to get HOT. I'm gonna be cooling it using a water cooled heat sink. But that is not a problem for me, I really wanted to do this with just an LM317. But then i will start looking for another volt regulator! – Xane Feb 04 '16 at 23:38
  • Start looking for a buck regulator circuit that can do current limiting efficiently - there are circuits about via google. Also be aware that you ought to consider "accepting" answers to previous questions you've raised that have useful answers. Call it pay-back time for all the great and useful info you get free of charge!! – Andy aka Feb 04 '16 at 23:39
    Much worse than the regulator heat is finding a good pot (not a rheostat) which will handle 1.2 amps through the wiper. – WhatRoughBeast Feb 05 '16 at 04:06
  • @WhatRoughBeast I don't disagree but as the op asked for heat from the current limiting part I explained that it could be as high as 23 watts. I regard the LM317 as at the heart of "the current limiting part". – Andy aka Feb 05 '16 at 09:29
  • You can't use a linear regulator as Andy aka told you. You need a switching regulator that limits the current to 2A and outputs 1.25V and 10mA at 10V. You need a current sensing circuit to sense the current and adjust the bias voltage at the feedback pin of the switcher. I've done this kind of circuit and it works pretty well. – lucas92 Feb 05 '16 at 21:27
    "You have problems and you need to listen-up." is an inappropriate comment to put in an answer. Stop acting like somebody's drill sergeant or father. – johny why Jun 05 '22 at 18:33
LM338 solves the 3 A requirement. It is good for 5 A, if used with an appropriate heatsink. This is the largest linear regulator in current production, that is normally available.
It is possible to parallel LM338 even x 3, if you know what you are doing. The National Semiconductor example shows only a master and one in parallel, but if you add extra op amps and half the sense resistor, you can go for three or even four with the original master regulator.
SamGibson
  • 17,231
  • 58
Tim Fidler
