Given the presented code, an object dump of the headers will show something similar to the following:
pic32-objdump -x main.o
9 .rodata 00000004 00000000 00000000 00000360 2**2
CONTENTS, ALLOC, LOAD, READONLY, CODE
10 .headerdata 00000004 00000000 00000000 00000364 2**2
CONTENTS, ALLOC, LOAD, DATA
This shows that the section in which header data is placed does not have the READONLY and CODE attributes and this in turn causes the linker to operate differently on the data from that section. In my limited tests, it would seem that content in .headerdata
is treated as other data, meaning that it is put into a special section named .dinit
and loaded from flash to RAM on program startup. You mention that the data from the .headerdata
section doesn't appear in your hex file - I suspect you'll find it in the .dinit
section.
If you are trying to get functionality similar to .rodata
but with your own section name, you will need to mark your .headerdata
section with an additional r
attribute like this:
static const MODULEINFO SER_05_ModuleInfo __attribute__((section (".headerdata,r"))) =
resulting in an object header dump as follows:
This will then be treated similar to .rodata
in the linker as long as you have added your special linker script snippet as listed.
I presume that you're trying to make your header the first set of data that is present in program space. Although the linker script additions you have listed would appear to work, I usually prefer to just add the additional sections in line with existing sections in the preferred order. Instead of a separate .headerdata ORIGIN(kseg0_program_mem)
type section, you could edit the .text
section to end up with something like this:
.text :
*(.headerdata)
*(.stub .gnu.linkonce.t.*)
KEEP (*(.text.*personality*))
*(.mips16.fn.*)
*(.mips16.call.*)
*(.gnu.warning)
} >kseg0_program_mem
Using pic32-objdump -d main.elf
will show a complete disassembly of the final binary in which you should now see your header data at the correct address.
You may want to check that placing your header at the start of program space does not upset operation of other parts of the system such as exception handling.
I found a copy of pic30.c
gcc compiler code floating around on the web somewhere and the accepted section attribute flags appear to be:
b - BSS
x - Executable code
r - Read only data
d - Writeable data
