As part of my current workflow producing a PCB layout I open my gerber files using gerbv. This allows me to switch on and off layers and check things are as they should be.
However I need to present the layout to some others in my team, preferably without needing gerbv. Currently I do this by offsetting all of the layers so they can be seen individually and then print to PDF.
This is pretty tedious and I cant help thinking there is a better way, so are there any gerber viewers that support the following.
  • View a stack of layers from each side of the board (Would be great if this was something like the graphical view OSH park creates - example)
  • Display each layer separately, without manual offset adjustment
  • Output to PDF
Hugoagogo
  • 2,405
  • What's the budget? – Asmyldof Jan 28 '16 at 01:09
  • Budget of approximately <$100 – Hugoagogo Jan 28 '16 at 01:23
  • Nice silkscreen message in the sample! I should learn to be more romantic :) – bitsmack Jan 28 '16 at 01:23
    I didn't even notice when I picked the sample (not mine) – Hugoagogo Jan 28 '16 at 02:01
    There are advanced tools that will take your cad drawings and gerbers and perform all kinds of analysis on them, typically this is something that a PCB manufacturer will do for you during the DFM review before ordering. Otherwise these tools start in the several thousand dollar range (e.g. [Valor](https://www.mentor.com/pcb-manufacturing-assembly/) ), For the simple things you need and the budget you have its probably easier to either build in the features into gerbv yourself, or script it to do what you need. – crasic Jan 28 '16 at 02:25
For checking gerbers, I use GC-Prevue, but it's not much different from gerbv.
If you want to generate presentable images and your CAD tool does not offer that, try looking at some 3D gerber viewer tools:
  • 3D Gerber Viewer is an online tool and does a decent job, similar to your example.enter image description here
  • ZozfPCB is a desktop application and seems to have quite a few features. It was a bit fiddly to use last time I tried it, though.
Armandas
  • 7,845
  • 32
  • 56
  • +1 for GC-Prevue. I was about to mention it but then I noticed you already suggested it. I don't know if GC-Prevue (the free one) will be enough though, I can't remember if it has a direct PDF export or not. I know some of the paid versions do though. – DerStrom8 Jan 28 '16 at 12:41
It's a very late answer and I'm sure the original poster no longer needs this, but the problem is common enough and still exists.
One way to achieve this is to use gerbv to make the various layers, then Image Magick's montage and convert programs to create the file you want.
The basic idea is to use gerbv on the command line to generate intermediate images; the rest is ordinary graphics not specific to gerber.
In Linux or similar shell, scripting that is pretty straightforward.
Here are parts of an image showing stacks on the left (just copper and solder mask, red=top, blue=bottom) and the silkscreen of those layers.
Script:
#!/bin/sh
# gerber2pdf
# convert gerber files to review pdf
# jonathanjo/2020-06-01
set -e
if [ $# -ne 1 ]; then
    echo "Usage: `basename $0` filenamebase" >&2
    exit 1
fi
fn="$1"
tcopper='#ff0000'
bcopper='#0000ff'
mask='#ffffff40'
silk='#ffffffff'
outline='#ffff00'
pcb='#004000'
dpi=1000
tmp=/tmp/$$
for x in COPPER-TOP SOLDERMASK-TOP SILKSCREEN-TOP \
    COPPER-BOTTOM SOLDERMASK-BOTTOM SILKSCREEN-BOTTOM \
    OUTLINES; do
    f="${fn}_${x}.gbr"
    if [ ! -f "$f" ]; then
        echo "`basename $0`: $f: no such file" >&2
        exit 1
    fi
done
gerbv -D $dpi -B0 \
    -b$pcb \
    -f$mask ${fn}_SOLDERMASK-TOP.gbr \
    -f$tcopper ${fn}_COPPER-TOP.gbr \
    -f$outline ${fn}_OUTLINES.gbr \
gerbv -D $dpi -B0 \
    -b$pcb \
    -f$mask ${fn}_SOLDERMASK-BOTTOM.gbr \
    -f$bcopper ${fn}_COPPER-BOTTOM.gbr \
gerbv -D $dpi -B0 \
    -b$pcb \
    -f$silk ${fn}_SILKSCREEN-TOP.gbr \
gerbv -D $dpi -B0 \
    -b$pcb \
    -f$silk ${fn}_SILKSCREEN-BOTTOM.gbr \
# many variants of the following also sensible
montage -geometry +10+10 -label '%f' \
    $tmp.topc.png $tmp.tops.png \
    $tmp.botc.png $tmp.bots.png \
convert ${fn}.png ${fn}.pdf
rm -f $tmp.*
# end
jonathanjo
  • 12,049
  • 60
To view your gerber files, I use an free, online Gerber Viewer to check my board size, hole and track sizes and clearances of the various PCB objects.Easy to use, just drag and drop your Gerber files here Or upload it here: https://gerber-viewer.easyeda.com/
It's no need any download or installation, works in modern web browsers on Windows, Mac, Linux. Easy to see all the detail of PCB parameters before making PCB to production.
