Our device is specified to have a display brightness of 500 cd/m² and it must not decay to less than 50% brightness in 50,000 hours. Now, I can't wait for 5.7 years for that test to finish.
I guess that this issue has been solved before. How is decay in brightness measured?
I know how to measure the brightness at a point in time, e.g. with a Gossen M504G.
Olin Lathrop
  • 310,974
  • 428
  • 915
Thomas Weller
  • 1,008
    So you promised some specification without knowing how to test that specification? – PlasmaHH Jan 26 '16 at 13:33
  • I don't understand. Are you holding a display specified that way, and want to include it in your device, or are you building a device that needs to meet that spec?? – Scott Seidman Jan 26 '16 at 14:30
  • @ScottSeidman: it will be built by a 3rd party company, integrated into our device and I have to test it. – Thomas Weller Jan 26 '16 at 15:31
    @PlasmaHH: yes, that's what it looks like to me. So it has happened, it's not my fault and I'm at least thinking about it – Thomas Weller Jan 26 '16 at 15:33
    @PlasmaHH Why are there always those guys looking for an opportunity to call someone out just for asking a question? You don't know answer and have no constructive comments? Well, just move along. – Tomáš Zato Jan 26 '16 at 16:27
The normal way people handle this is to devise a model for how the degradation rate varies with, say temperature, input current or luminosity, parameters that would reasonably be expected to influence the failure rate.
They then test this model, by driving devices to failure at high temperature or 200% rated output, and seeing if the graph of failure time versus aggravating factors follows the predictions of their model. This is known as 'accelerated life testing'.
Then having confidence in the model, they extrapolate from it to predict what the failure rate is expected to be with less severe conditions.
Obviously, the validity of this approach depends on the quality of the model. The key word that should ring alarm bells is 'extrapolate', is it still a straight line fit in the region you haven't made any measurements? You can boost public confidence in your predictions by publishing the model, and in particular, the activation energy you derive from any power laws that you manage to fit. It's only after many years have passed that you'll see whether your model was correct or not, if you are still doing and observing the appropriate experiments that is!
Look on wikipedia for 'accelerated life testing' and 'Arrhenius plots', to see how this sort of approach tries to model temperature dependence, and to see what I mean by activation energy.
A difficulty in your particular case could be that I would expect there to be a dependence separately on both operating temperature and luminosity, which will complicate the construction and verification of the model.
Neil_UK
  • 158,152
  • 173
  • 387
    For a quick sanity-check, if you have a very sensitive luminance meter, measure it in a light-proof and temperature-controlled room for a week or a month, then graph the delta over time, and fit this to a trend line in Excel, extrapolating over 50k hours. It won't be accurate of course, but if a trend fits to \$R^2=0.992\$ and shows it will be 10% luminance at 4 years, then it's time to worry. – rdtsc Jan 26 '16 at 14:24
  • Another factor to consider is capacitor aging, voltage rating, ripple current, etc. If you use low-quality caps in harsh environments, they may fail long before the illuminator does. – rdtsc Jan 26 '16 at 14:29
Without actually running the test, you can't know that your display doesn't decrease in brightness more than the specified amount.
If you are buying the light-emitting part of your display from someone else, then get them to specify how much the brightness reduces over time.
If you are building these things yourself, then you have to understand your own process. Ask the people that came up with the 50 kHours spec how they decided the displays could do that.
The people that understand the process and have experience with it probably also know how to do accelerated tests that they have found to be valid in the past. If you are starting from scratch, then you really do need to wait 5.7 years for a valid answer.
Olin Lathrop
  • 310,974
  • 428
  • 915
  • I should think that the light source is only part of the issue; if transmissivity diminishes that could also result in degradation of overall brightness. – Ben Voigt Jan 26 '16 at 19:00
